Home > In Car Electronics (L322) > Mid
Matcossy
United Kingdom 2003 Range Rover HSE Td6 Rimini Red
Mid
Hi, chaps last night I disconnected my battery to charge but refitting I now do not have my info i.e. Mpg av Milan speed distance and things in my mid on my radio or on the dash
I have tried resetting it in check control in the dash but it's not worked
I got a iidtool but that's no help really any thoughts.?
Post #415579 27th Nov 2016 1:33pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
did you do proper shut down before disconnecting battery?
Post #415592 27th Nov 2016 2:55pm
Matcossy
Mid
Hi I left with the bonnet up and unlock for about 30 min then disconnected the battery and it was about an hour befor reconnect
Post #415600 27th Nov 2016 4:34pm
Weegie
"Effects of battery disconnection
Following disconnection and subsequent
reconnection of the vehicle battery, a number of
the vehicle systems will be reset automatically.
This may take a few minutes and with some
systems, sensors have to detect certain actions
whilst driving before full operability returns.
This in no way affects the safe operation of the
vehicle."
Wonder if that helps. Also after reconnection, with engine running, turn steering from full lock to full lock.
Let's know how you get on. John
GAP iiD BT
Post #415602 27th Nov 2016 4:52pm
builder1966
hope you get sorted bud bloody nitemare these motors !
Post #415603 27th Nov 2016 5:12pm
Matcossy
Mid
I was hopeing going for a 30 mile round trip solv it but alas no changes
Post #415606 27th Nov 2016 5:23pm
Weegie
Did you try the full lock to full lock? John
GAP iiD BT
Post #415608 27th Nov 2016 5:51pm
Matcossy
Mid
Yeah lock to lock done.
Mybe I should try disconnect of battery again?
Post #415767 28th Nov 2016 10:58pm
Weegie
Try that with the method of touching the two leads together to reset. . John
GAP iiD BT
Post #415790 29th Nov 2016 8:27am
Matcossy
Mid
Ok I have tried the resetting but still no lock it drives fine ,,it's just the display and fbh that's inop it's doing my head in now I'm even thinking of selling up
Post #415881 29th Nov 2016 7:28pm
Weegie
Have you checked all the fuses, including the ones in the boot? Also the connections in the boot. Although a battery disconnect stranger things have happened. John
GAP iiD BT
Post #415882 29th Nov 2016 7:35pm
