Home > Maintenance & Mods (L322) > Which oil is best?
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Which oil is best?
Land Rover recommend an oil, something like Shell Helix Ultra professional AF-L or Castrol C1 Edge Professional. 5w30.
The ACEA C1 spec is low viscosity. Helps with fuel economy. C spec is needed with the dpf filter being low ash.
However, if you don't care about the fuel economy so much, and are more interested in protecting your engine, is ACEA C4 better? Will ACEA C4 look after your turbos better for example?
Post #415435 26th Nov 2016 10:02am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Sounds like an interesting question.... If C1 is low visc do I take it C4 has a higher visc?
For the 4.4TDV8 and Opie recommendations are all C1. Surely anything other than the LR recommended grade is a risk?
http://www.opieoils.co.uk/c-2355-lookup-re...ilter=2010 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #415443 26th Nov 2016 10:48am
Rambles
My hypothesis is the other way round....to achieve a marginally improved fuel consumption owners are taking a risk with their engines....and they could achieve better longevity and reliability for the sake of a few less mpg....
Post #415483 26th Nov 2016 7:11pm
