Home > Maintenance & Mods (L322) > new jack
alistairh
new jack
Ok..next step for me is binning that god awful jack that's next to the compressor...just checking these are the right parts? Once here does the mini adaptor need drilled into said jack?
Post #415417 26th Nov 2016 8:51am
Weegie
Parts are right. Just need to drill a 16mm hole in the bottom of the adapter so that it fits over the jack. Not right through!! Smile
You remove the "cow horns" from the jack by pushing out the retaining pin. Some drill the side of the adapter to fasten it on to the drill but it isn't necessary as the weight will keep it in place. It also has the advantage that, if you have a trolley jack, you can use the pad on it. John
GAP iiD BT-Sold
Post #415419 26th Nov 2016 9:26am
You would be better with a metal version of the adapter - they do exist but harder to find.
That one is a tough rubber, so OK as a lifting pad, but not as good with a hole drilled through the middle of it
Alternatively, you can take a grinder to the jack itself - there's some ideas on this thread Thumbs Up
Post #415424 26th Nov 2016 10:12am
Weegie
I agree about the metal one. Got mine here:
http://www.ebay.co.uk/itm/BMW-JACKING-PAD-...Swo0JWFgRG
by far the cheapest. John
GAP iiD BT-Sold
Post #415426 26th Nov 2016 10:20am
alistairh
Thanks for advise and links guys Thumbs Up Will get the metal adaptor as well...
Post #415434 26th Nov 2016 10:54am
Baltic Blue
In Blue Peter speak,
Here is one I made earlier.
Just bent the galvanised nail slightly to make it a tight push fit.
Post #415440 26th Nov 2016 11:43am
Rob99
My sprinter jack is due any day so will also be buying an adaptor.
With the metal one is it easy to drill a 16mm hole in the bottom? I don't have a pillar drill or anything similar which would have been ideal Big Cry 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #415441 26th Nov 2016 11:45am
Weegie
The metal one is aluminium so easy to drill. The most difficult part will be ensuring it is at right angles. Don't you have a friendly garage nearby or someone with a pillar drill? John
GAP iiD BT-Sold
Post #415448 26th Nov 2016 12:16pm
Rob99
Thanks John Thumbs Up
Thinking about it my father used to have one so probably buried in his shed somewhere. Will have a look next time I am there. 2021 D350 Fifty Edition - Carpathian Grey
Post #415452 26th Nov 2016 12:30pm
Baltic Blue
Sorry for sending so many photos, I am trying to learn how to get them the right way up .
:blub
Post #415453 26th Nov 2016 12:34pm
Baltic Blue
A simple Heath Robinson mod that works OK if you can't drill the 16mm hole.
Find a plastic bottle top that is just over 16mm diameter.
Use a self tapping screw to connect it to your rubber pad, such that it just pushes over the 16mm piston
The plastic threads inside the cap just grip the piston sufficient to hold it firm.
I think the one I played with came off a small bottle of cough medicine. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #415599 27th Nov 2016 5:21pm
Weegie
The problem with that is that, under load, you are depending on a self tapper into rubber to remain stable if there is any lateral force when jacking the vehicle. I wouldn't be happy. Sad John
GAP iiD BT-Sold
Post #415694 28th Nov 2016 1:37pm
Roverlord
England 2003 Range Rover HSE Td6 Zambezi Silver
I too bought a sprinter jack, but found the other day when I had a flat that the sprinter jack was but a little bit tall about 10 mm to slide under the Rangie, I had to raise the suspension to get the clearance to slide it under .
Post #415699 28th Nov 2016 2:56pm
Baltic Blue
The adapter mod adds a further 15mm to the overall height, but it fits in easy with the suspension raised, and then easily lifts the car sufficient to get the flat off and the new wheel on. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #415700 28th Nov 2016 3:13pm
dirtymonkey38
Do you still have the photo?
 2011 RR Autobiography 4.4 TDV8
Post #480716 11th Jun 2018 7:56pm
