Home > Technical (L322) > FBH issues
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
FBH issues
FBH works fine when engine is running but tying to use it remotely with fob turns it on for about 3 or 4 minutes then it cuts out , any ideas ?
Post #414897 23rd Nov 2016 10:48am
battery? ... - .- -.
Post #414898 23rd Nov 2016 10:51am
andygts
as above, are you getting random messages when starting the car aswell such as HDC inavtive or special programs off? Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #414899 23rd Nov 2016 11:05am
matthews
No issues starting at all , no random warnings , everything seems fine battery wise , plugged my Delphi DS150 in to read out fault codes nothing showing up , battery voltage reads 12.09 at rest , drops to 11.99 when internal fans come on on initial startup then goes back up to 12.09 when fbh running but internal fans turn off and fbh keeps running , then fbh turns off .
Post #414901 23rd Nov 2016 11:18am
Rob99
I think a reading of around 12v (assuming its an accurate reading, as lots of voltmeters have an error factor) would be marginal for the FBH to operate IIRC. 2021 D350 Fifty Edition
2017 4.4 SDV8 Autobiography -
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #414904 23rd Nov 2016 11:33am
TomCobbly
The FBH is supposed to work down to 11.5V but not sure if that is battery voltage or voltage at the Webasto end of things as there will be a voltage drop I would have thought.
Also you may need to check your CCF settings as there are some things that need to be enabled for auxiliary heating as opposed to just warming the engine up quickly when starting from cold. That said, if you have the remote and it works then your CCF settings ill almost certainly be enabled.
Post #414916 23rd Nov 2016 1:00pm
matthews
Well further investigation ensued , charged battery , connected multimeter (calibrated fluke 23) and tested again , battery voltage never dropped below 12.8V (when internal fans running ) but still only runs for 5 mins at a time , both with manual heat or timer from touchscreen or remote control .
Post #415328 25th Nov 2016 2:45pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
It is probably your water circulation pump, have a look at this thread from the Rover 75 forum Thumbs Up
http://www.the75andztclub.co.uk/forum/showthread.php?t=100297 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #415329 25th Nov 2016 3:02pm
matthews
Well it gets stranger but better , after not getting to the bottom of my issues it now appears to be working , last night upon leaving work it felt warm in the car when I got in and this morning I was nicely defrosted and warmish before going to work (turned it on with remote before breakfast , hope it stays this way , maybe it just wasn't cold enough last week .
Post #415799 29th Nov 2016 10:44am
SveinHa
Norway 2008 Range Rover Vogue TDV8 Buckingham Blue
I believe this may be exactly the same problem I have. Connected my Lynx tool today, fired up the FBH, flame present, water temp increasing up to 90 degC, fuel pump shut off, water temp increasing to 105degC and then cooling down, ice cold air thru the vents all the time. Water pump indicated "Running" but it seems quite reasonable that it didn't run. No error codes. My first step will be checking water pump. "Plentraktoren/Garden tractor": 2008 L322 TDV8
"Project": 1990 90 County 300tdi
Post #415808 29th Nov 2016 1:10pm
TomCobbly
The exact thing has happened to me. This morning I set the FBH using the remote but when I went out to the car 15minutes later the FBH had stopped but I could tell it had been on by the small area at the bottom of the windscreen which had defrosted but inside the car was cold. Big Cry
I then set the FBH timed to come on 15 minutes before I got back to it after work and wasn't very hopeful it would work especially as the drive to the station is only 10 minutes and I was thinking it might be a battery charge problem.
Imagine my surprise when I got to the car to be greeted with the FBH running and the inside of the car toasty warm Very Happy Thumbs Up
I'm going to try again tomorrow with the remote and see if I get the same result as Matthews.... fingers crossed!!
Post #415879 29th Nov 2016 7:18pm
TomCobbly
Well I set the FBH with the remote this morning and to my surprise it was still running when I got to the car and it was -4 C outside and 22 C inside.... Toasty!! Thumbs Up
I can't understand why it should work today and not yesterday which was -3 C. The only difference was that the timer is now set for the evening Question Exclamation 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #415935 30th Nov 2016 8:35am
Dolphinboy
French mike is the FBH guru
http://www.the75andztclub.co.uk/forum/showthread.php?t=71982
Post #415937 30th Nov 2016 9:14am
TomCobbly
I don't believe ther is anything wrong with the FBH. I tested it on my GAPIID and all was fine. If there is a problem at all now I think it must be something to do with the Range Rover software Rolling Eyes
According to the diagnostic tool there are lots of ECU modules which don't have the latest update but Patrick at GAP advises to leave well alone if there aren't any problems. The jury is still out on that one? Neutral 2011 4.4 TDV8 Vogue SE
Post #415942 30th Nov 2016 9:46am
