Home > Technical (L322) > Alternator? |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Battery light started flashing intermittently this morning. Just plugged in the IID and it's showing 11.4 volts and doesn't increase with revs. I'm guessing the alternator has gone.
15th Nov 2016 8:06am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
the smell is the diesel , the alternator should ideally push out around 14.2 volts.. ... - .- -.
15th Nov 2016 8:17am |
This isn't a diesel smell Stan. Nothing like |
15th Nov 2016 8:19am |
Sounds like the smoke has escaped from the alternator. Take it to a place where they can put the smoke back in.
15th Nov 2016 3:20pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Disconnect the battery as a damaged diode back can short the battery and kill it pretty quickly |
15th Nov 2016 3:32pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
^ You don't need to change the alternator and battery together.
24th Nov 2016 8:07pm |
Boodog Member Since: 23 Mar 2016 Location: Wales Posts: 5 |
Thanks. New alternator having read a few posts on it - ouch! Thanks for the advice though |
24th Nov 2016 8:13pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Boodog,
25th Nov 2016 10:38am |
Thanks for such a comprehensive reply Weejock. I went for a 3rd opinion today with our local tyre/exhaust/battery dealer and they said same as National Tyres and yourself so I definitely won't be going down the new alternator route until I've checked everything else including charging the battery and the testing. The car is a 2003 4.4 V8 petrol. My wife uses it but only for local runs averaging around 8 miles from start to stop (home to shops) and given the quantity of electrics and electronics on the RR I suspect the battery isn't getting sufficient charge between start/stops.
25th Nov 2016 5:22pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
Have just replaced our battery in the Black Friday sales and have ventured into the cold harshness of the north- all seems to be much better now...... |
28th Nov 2016 11:23pm |
