![]() | Home > Technical (L322) > Alternator? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Battery light started flashing intermittently this morning. Just plugged in the IID and it's showing 11.4 volts and doesn't increase with revs. I'm guessing the alternator has gone.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
the smell is the diesel , the alternator should ideally push out around 14.2 volts.. ... - .- -.
This isn't a diesel smell Stan. Nothing like |
Sounds like the smoke has escaped from the alternator. Take it to a place where they can put the smoke back in. |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Disconnect the battery as a damaged diode back can short the battery and kill it pretty quickly |
^ You don't need to change the alternator and battery together.
Boodog Member Since: 23 Mar 2016 Location: Wales Posts: 5 ![]() ![]() |
Thanks. New alternator |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Boodog,
Thanks for such a comprehensive reply Weejock. I went for a 3rd opinion today with our local tyre/exhaust/battery dealer and they said same as National Tyres and yourself so I definitely won't be going down the new alternator route until I've checked everything else including charging the battery and the testing. The car is a 2003 4.4 V8 petrol. My wife uses it but only for local runs averaging around 8 miles from start to stop (home to shops) and given the quantity of electrics and electronics on the RR I suspect the battery isn't getting sufficient charge between start/stops.
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Have just replaced our battery in the Black Friday sales and have ventured into the cold harshness of the north- all seems to be much better now...... |
