![]() | Home > Maintenance & Mods (L322) > rounded /stripped torx |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
Not knowing what kind of access you have as I haven't done mine yet, I would look at using a dremel or such to cut a slot in and use a large screwdriver.
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 ![]() ![]() ![]() |
Sadly I had the same issue and my only option was molegrips however the threads were so heavily corroded they snapped off. |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I will try the moleys first and keep my fingers crossed, mines are badly corroded as well....ive not got a dremmel in my toolkit yet so if that fails there's my excuse to purchase one |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
Have you soaked it in WD or other penetrating oil first ? |
Yeah sprayed wd40 on it a couple of times in the past 24 hours hoping it would help..it didn't |
It wouldn't, contrary to popular belief WD40 isn't a penetrating fluid and is actually hygroscopic, it actually attracts moisture.
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
I use an oil from the poundshop it used to be called DP90 not sure of it's name now (got about 20 cans on the shelf) it's amazing stuff I did a little serch on it and the DP90 got great reviews much better than WD40
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 ![]() ![]() ![]() |
drill it then use an easy-out screw extractor. they are a set of 5 conical bits with a course reverse thread
Thanks guys..shall have a read up and source 1 of them before I attempt to get the torx heads out..there is a tiny bit of grip left in the rounded heads so I'm hoping one of your recommendations gives it some movement... |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hammer in a hex bit? It might get a better purchase... failing that a cobalt drill bit |
Hmb Member Since: 12 Jun 2016 Location: Essex Posts: 90 ![]() ![]() ![]() |
50/50 mix acetone atf 2010 Overfinch 3.6 V8 FFRR gone yee haa
I've been scooshing torx heads all day with penetrating spray..hoped it would loosen things up..eventually tried to hammer in a hex bit and hoped for the best..never worked..looks like its a drill job at the weekend..only wanted mirrors off to restore bubbled backing plate..was going to get then repowdercoated tomorrow |
