Home > Technical (L322) > HDC Inactive message
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Have you checked the voltages at the battery when it's at rest and when it's running. When doing the running test carry out the tests under load and no load.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #414921 23rd Nov 2016 1:21pm
handyandy1966
Took the car to main dealer to have it tested they say alternater is fine brand new battery fitted by them then this starts shall I just get a new alternate fitted?
Post #414922 23rd Nov 2016 1:27pm
UK Marine
Not yet, there's a couple of other things we can try. I'm not saying that voltage is your problem but it's usually the problem when HDC pops up with no other associated faults.
It could be that your car isn't sleeping when it should be. Have you tested the voltage at the battery first thing in the morning after it's been stood for a while, this could indicate that something is drawing on the battery when it should in fact be asleep.
The main culprits are the FSR and the sat nav.
The sat nav you can test very easily, first open the tailgate then fold back the parcel shelf. Open the left side cubby so you can see the sat nav unit, then close the tailgate and don't lock the car, wait about 5 mins. After those 5 mins look through the rear screen, don't open the tailgate, the sat nav light should be out if it is out all is well, if the light is still on then there is your drain.
The FSR can usually be responsible for running the fans etc when the car is locked and should be asleep. It's very easily replaced (there is a procedure in the wiki section) and can be obtained from Dan at Duckworths here on the forum, just message him for a price.
The first thing for me though would be to check your battery first thing in the morning before you start it.
Simon
Post #414925 23rd Nov 2016 1:43pm
handyandy1966
Tbh I only put it in garage to have work done so will arrange for them to keep it overnight and check tbh dont have much faith in beadles southend
Post #414926 23rd Nov 2016 2:14pm
UK Marine
Good luck with your investigations. Keep us informed with your findings.. ______________________________
Simon
Post #414927 23rd Nov 2016 2:18pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
Thumbs Up feel the same with beadles cut so many corners
Post #414951 23rd Nov 2016 4:48pm
miggit
Embarassed Wrong page Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #415025 23rd Nov 2016 8:49pm
