![]() | Home > Technical (L322) > HDC Inactive message |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
Have you checked the voltages at the battery when it's at rest and when it's running. When doing the running test carry out the tests under load and no load.
Not yet, there's a couple of other things we can try. I'm not saying that voltage is your problem but it's usually the problem when HDC pops up with no other associated faults.
handyandy1966 Member Since: 14 Oct 2015 Location: Essex Posts: 20 ![]() ![]() |
Tbh I only put it in garage to have work done so will arrange for them to keep it overnight and check tbh dont have much faith in beadles southend |
Good luck with your investigations. Keep us informed with your findings.. ______________________________
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
