Home > Maintenance & Mods (L322) > One Sump Plug or two |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 610 |
There are two.
20th Nov 2016 2:43pm |
Pat Member Since: 20 Nov 2016 Location: Airdrie Posts: 55 |
Hi never Heard of this before do you know why it has two sump plugs |
22nd Nov 2016 10:41am |
If I remember correctly the sump has a baffle in the middle so that regardless of the angle the vehicle's at the pump should always get oil. Doesn't normally matter on road vehicles but on the kinds of angles these are capable of it comes into play.
22nd Nov 2016 1:40pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2501 |
The turbos drain into a separate reservoir towards the rear which if not drained ends-up becoming filled with sludge, risking proper flow from the turbo drains. |
22nd Nov 2016 7:48pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
I think early 3.6 tdv8 engines might have only one because I have ordered service kits from the UK for a 2007 3.6 and a 2011 3.6 and the 2007 had 1 oil plug while the 2011 had two. I'm very far from an expert on this so please check or listen to way more knowledgeable posters on here 2015 4.4 AB
22nd Nov 2016 8:00pm |
