Home > Maintenance & Mods (L322) > One Sump Plug or two
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Hi want to change oil and filter on my 2007 Range Rover Vogue SE 3.6 TDV8 I am a bit confused as to the number of sump plugs I have read on a forum here that there are 2 but elseware of web there seems to be only one Can anyone help Thanks
Post #414528 20th Nov 2016 2:36pm
sako243
There are two.
One of them is above the sub frame cross member and makes a mess when you undo it...
Rolling Eyes Ed
Post #414529 20th Nov 2016 2:43pm
Pat
Hi never Heard of this before do you know why it has two sump plugs
Post #414782 22nd Nov 2016 10:41am
sako243
If I remember correctly the sump has a baffle in the middle so that regardless of the angle the vehicle's at the pump should always get oil. Doesn't normally matter on road vehicles but on the kinds of angles these are capable of it comes into play.
Similar reason but different implementation with race cars where sustained cornering might keep oil away from the pick-up. Where this might be an issue they tend to be dry-sump designs though. Ed
Post #414798 22nd Nov 2016 1:40pm
GraemeS
The turbos drain into a separate reservoir towards the rear which if not drained ends-up becoming filled with sludge, risking proper flow from the turbo drains.
Post #414841 22nd Nov 2016 7:48pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I think early 3.6 tdv8 engines might have only one because I have ordered service kits from the UK for a 2007 3.6 and a 2011 3.6 and the 2007 had 1 oil plug while the 2011 had two. I'm very far from an expert on this so please check or listen to way more knowledgeable posters on here 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #414843 22nd Nov 2016 8:00pm
