Home > Technical (L322) > Fitting deployable steps |
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 |
I tell a lie, there was no spade in the 23 it's the blank one next to it see photo
19th Nov 2016 8:33am |
Sorry see here
19th Nov 2016 8:35am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8500 |
are you sure you have the right kit/instructions for the wiring.
19th Nov 2016 9:33am |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 |
Fitting mine today, the instructions look as they cover pre and post 2010 models, pre 10 (page 5 drawing 20) shows the feed piggy backs into a terminal, post 10 (page 8 drawing 34) shows the pin 19 your referring to.
19th Nov 2016 10:18am |
Nearly finished mine, the interior switch isn't working for some reason but they deploy on unlock, and when a doors opened, also the programming procedure obviously can't be done with no ignition 2018 Suzuki Jimny 2003 written off
19th Nov 2016 2:02pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3774 |
Now I feel better at paying to get these supplied and fitted, where the technically able seem to struggle. I would have no chance Geoff |
20th Nov 2016 9:42am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
me to Geoff , and they stop working the dealer will sort it... ... - .- -.
20th Nov 2016 10:46am |
just to add that i admire those who are attempting to fit these themselves but as mine has a LR warrantee i have to be careful what and how stuff is fitted... ... - .- -.
20th Nov 2016 11:37am |
Mine fitted ok, straight forward following the instructions, took me longer than 2.5 hrs Land Rover say it takes, and they have 2 year warranty from LR. SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
20th Nov 2016 1:16pm |
Yeah it was a pretty big job, took me about 4 hours but a chap came and remapped the ff and a golf in that time, how did you got about programming the switch 87rjd? Also with your wiring loom did you have two plugs which didn't connect ton anything? Close to the fuse box area?
20th Nov 2016 5:29pm |
Hi
21st Nov 2016 5:54pm |
Yep I'm pretty sure I did those you're on about, you unplug one from the metal ecu looking thing, plug one in from the loom to the ecu and the other which originally came from the ecu into the loom?
21st Nov 2016 6:10pm |
No spare wires or plugs on the loom I had for my car, it had a label showing it was for My07, so I know it was the right one. Followed the sequence with the ignition key and button to enable/disable, and to deploy both step so you can stand on them to clean the roof.
21st Nov 2016 10:03pm |
Ah fair enough, I miss read your car details, thought it was 2012 👍🏼
21st Nov 2016 10:06pm |
