Home > Technical (L322) > Driver's external door pull.
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
After a long weekend at the NEC I came back to the Rangey and, being in a knackered state, made the mistake of pulling the door handle at the same moment as I unlocked the door on the remote. So now the door handle cable has either disengaged or broken. Which is it most likely to be? I don't want to dismantle it twice ideally but neither do I want to buy a cable I may not need!
Ta muchly!
Post #413673 15th Nov 2016 7:46am
if the inside handle still works then the outter cable has broken.. ... - .- -.
Post #413674 15th Nov 2016 7:49am
Zeb
Thanks Stan! Inside door pull is fine so I will order a new external cable...☺
Post #413679 15th Nov 2016 8:15am
