Home > Technical (L322) > sensor data readings |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8243 |
If you just watch the o2 sensors readings they should cycle between around 0.3 to 1.2 or close, the engine ecu richens the mixture until the o2 sensor says it's rich, then it leans out the mixture until the o2 says it's lean, this happens many times per second, no need for faffing with filters or spraying extra fuel in... the o2 sensors are also checked by the post cat sensors and if they don't agree, i,e one is faulty, then you get a MIL light on...
13th Nov 2016 9:38pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Magic 02 readings are bouncing about between 0.025 to 0.070 and 0 025 to 0.82..will check the fuel trims tomorrow! Im slowing learning about this car and its workings so hugely appreciate the help! Cheers Pete...bedtime reading this week will be the rave manual ...lots of knowledge to soak up... |
14th Nov 2016 12:18am |
Ok I've managed to check the short term fuel trim..there's 2 sets.of readings .
14th Nov 2016 3:38pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1369 |
Gut feeling - your MAF is on its way out. The 4.4 BMW seems very sensitive to its air flow reading being correct if the sensor is attached. Is yours showing an engine management light?
14th Nov 2016 4:11pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
I've got some good maf readings here somewhere. Hold on I will have a look.
14th Nov 2016 5:30pm |
Here you go. These are known good readings. All loads off
14th Nov 2016 5:39pm |
@ fisha no warning lights or faults stored at all buddy..if I start car cold it idles at about 1500rpm for a minute or 2 then bounces between 500/600rpm. If I give it some gas in idle the revs drop,lights dim and it nearly stalls....it seems more stable with the air con switched on then after a while it does the bouncy rev trick again |
14th Nov 2016 6:32pm |
@rewmer ..i googled them somewhere Yeah idles all over the place....cars going in for a full service and pcv valve/pipes ect getting replaced...got a new battery delivered today as well so that's going in shortly then hopefully addresse the idle issue |
14th Nov 2016 6:38pm |
Sounds to me like an air leak into the inlet manifold somewhere, it's getting extra air in somewhere, hence the low tickover... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
15th Nov 2016 12:06am |
That doesn't sound too bad then! Matter if finding said leak..one thing I have noticed is if I quickly rev car there's a huge sucking,vaccum noise from the external air inlets (gills)..probably normal as I've never had a rangey |
15th Nov 2016 6:55am |
That's weird as they aren't anywhere near the air inlet, it's right at the front of the wing, this has my elbow on it for the snorle the original one points downwards...!!!
15th Nov 2016 4:40pm |
Great..weekends jobs are to solve this issue(hopefully) I presume when the revs drop and all the lights dim its to do with my bad battery? Just tested it under load and its just over 11v....new one arrived yesterday and is going in on Saturday..cheers |
15th Nov 2016 5:17pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 |
Daft question but do you have an air filter in the housing? That can usually attribute to a sucking vacuum sound. ______________________________
15th Nov 2016 7:19pm |
Yeah...just changed it...good point actually! I did have the air housing out to fit the drivers side headlight..i had a nightmare refitting the pipe at the bottom to the lower housing..maybe its not meeting right? Definitely never heard the sucking noise before it...only issue is I did have the problem idle before I fitted headlight |
15th Nov 2016 7:36pm |
