Home > Technical (L322) > Suspension leveling
Realist
Wales
Suspension leveling
Hi all,
FFRR 2007 SE
Since having the two EGR valves done on the FFRR and having the garage take a look at a knocking noise the front suspension looked high compared to the back end.
So tonight I plugged in my IIDTool and started going through the levelling guide which I think I did wrong.
Now when I press down nothing happens and when I press up all the dash says is "suspension slowly rising" and then a message says something like "please wait for the compressor to cool down" or words of that effect.
When I started the measurement the car was at its normal riding height and the GAP app said to measure from the middle of the wheel hub to the lower lip of the arch and it said 19 1/4" for the front and 19" for the back.
Well the back struggled to hit 18" and now since Ive saved the settings I can lower but rising takes ages and the above message shows up.
Any ideas?
HELP............................... Ta. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #413641 14th Nov 2016 10:20pm
If you push it up and down loads it drains the air reservoir and the pump has to do all the work, it wasn't designed to do that. It's supposed to pressurise the reservoir over a period then use that stored pressure is used to raise and lower the car. Those messages relate to the fact that the reservoir is depleted.👍 There is nothing that can't be fixed with a hammer😜😜
Post #413644 14th Nov 2016 10:31pm
Standard height settings are 493mm front and 483mm rear
Your measurements converted from inches are 489mm front and 483mm rear. The front heights you have are within tolerance range, but if anything lower than standard.
Front is set higher than rear for approach heights (I understand).
I have set my rear up by 15mm, as like you, felt the car looked like it was always falling backwards Wink
See my heights chart here:
http://www.fullfatrr.com/forum/topic12292....suspension .
Post #413648 14th Nov 2016 10:40pm
Realist
Wales
So what do I have to do now to reset it back to default.
Found this on here as well that may help:
Post #413649 14th Nov 2016 10:41pm
Realist
Wales
Hi Joe,
LOL great minds think alike just found your chart but what do I need to do so its back as it was before I Censored it up. Range Rover quotes.....
Post #413650 14th Nov 2016 10:42pm
Realist
Wales
If I press the level button the FF lowers to standard height and the display says standard.
If I press up the dash says slowly rising.
Post #413653 14th Nov 2016 11:15pm
miggit
Shocked I think I know what's wrong.. the car in diagram is an L405 they are 400KG lighter.. no wonder it thinks it's slow.. it's just put on half a ton Laughing
So it not getting up? Has it been doing the slow bit from cold? straight off? or has this happened whilst multiple height checks have taken place?
If it's straight from the word go then I suspect that the piston ring is past it's best.. whether you can get a rebuild kit for the later EAS pump is anyone's guess, I haven't seen them, but then I haven't really looked... but I can't see why they wouldn't make one. I'm sure that some nice peep will tell us Smile
Might be worth checking the boot for damp.. in the form of puddles.. the EAS pumps don't like being drowned and this can effect their performance.... Yesterday I couldn't spell Engineer... Today I are one!
Post #413656 14th Nov 2016 11:49pm
Realist
Wales
Before I attempted to level the suspension it worked 100% without fail. I have a feeling it's to high, when I press up the body lifts and continues to lift until the message shows.
After a few seconds then the cooling down wait message shows and if I press the level button on the above screen the body drops quite a way and levels out.
So what I'm trying to find out is at what point do I start taking measurements when it's at its lowest, middle or highest point.
Also, the screen on GAP IIDTool shows I'm -22ish on one wheel (not correct can't remember) so do I reduce this to zero on all corners? Range Rover quotes.....
Post #413666 15th Nov 2016 7:27am
Realist
Wales
I levelled the FF last night and the below pic shows the info but I can't use the up or down as I used to.
Post #413667 15th Nov 2016 7:31am
Realist
Wales
I know the sites been down but does anyone have a clue how I can reset the suspension back to how it was. Range Rover quotes.....
Post #413702 15th Nov 2016 3:24pm
on activation the iidtool saves all the settings so go into the restore menu and it will all go back .. ... - .- -.
Post #413703 15th Nov 2016 3:27pm
Realist
Wales
Your a star, trying now. Range Rover quotes.....
Post #413705 15th Nov 2016 3:55pm
Realist
Wales
I can remember seeing that option and it didn't work but tried it again and it seams to be working as normal.
Maybe the fact the compressor was hot causing the slow rise message.
Thanks. Range Rover quotes.....
Post #413763 15th Nov 2016 6:22pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Why 06 s dont show highway mode?
03 s have an icon showing highway height.
Is there a possibility its not lowering since it is not so stable.
Post #414125 17th Nov 2016 5:41pm
a 2006 FF goes down to highway [motorway] mode at 100 mph and not 60mph'ish as on the earlier FF's.. ... - .- -.
Post #414126 17th Nov 2016 5:45pm
