Home > Maintenance & Mods (L322) > 2011 L322 TD V8 Reverse light bulb upgrade |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
You'll be lucky with that one Bud... there is only the 6w and a 21w bulb as far as I know... the 6w is the feeble bulb that LR's fitted and the 21w causes meltdown..... I not sure if you can get LED bulbs that will plug straight in, as the base of the bulb isn't standard, it has offset pins, just to be awkward
14th Nov 2016 4:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35461 |
as Paul says, everything has been suggested from splitting the lights and inserting cob/led panels to wiring auxiliary reverse lights under the bumper...
14th Nov 2016 4:14pm |
fettling??
14th Nov 2016 4:17pm |
very sharp ... - .- -.
14th Nov 2016 4:19pm |
It's not often that you can claim to be the sharpest tool in the box
14th Nov 2016 4:26pm |
smartone Member Since: 25 Jul 2011 Location: uk Posts: 29 |
Thank you very much for the replies!
14th Nov 2016 4:32pm |
put in my car and it says that they fit.
14th Nov 2016 4:35pm |
sorry I meant that I entered the model of my car into the ebay tool and was told that they were suitable, but upon calling them I heard that they did NOT fit my car.
14th Nov 2016 4:40pm |
I suspect that they don't fit because its a tight squeeze to get the bulb in the lens, the hole isn't too big.... that is not to say that the hole can't be made bigger
14th Nov 2016 4:53pm |
you could take off the OE reverse light and replace the whole thing with something like this ,
14th Nov 2016 5:36pm |
Does anybody think these are worth trying??
16th Nov 2016 11:06am |
I wouldn't bother, 1, I have my doubts as to whether they will go through the lens hole... and 2, they are what looks to be "normal" clear led's, I would be surprised if they are brighter than the original
16th Nov 2016 12:40pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Can only be used off-road. Reverse lights are limited to two with a maximum of 21W each for road use |
17th Nov 2016 12:12pm |
''off road'' ......and that refers to the cob panels or aux reverse lights ?.... ... - .- -.
17th Nov 2016 12:18pm |
