Home > Maintenance & Mods (L322) > 2011 L322 TD V8 Reverse light bulb upgrade
smartone
2003 Range Rover Autobiography 4.4 V8 Java Black
Keen to find a current definitive answer to the best upgrade bulb please. No mods, no soldering, nothing that's going to melt the plastic.....no errors.
I believe that I'm looking for an H6, but just want to plug and go something decent.
Cheers !!
Post #413515 14th Nov 2016 1:17pm
miggit
Whistle You'll be lucky with that one Bud... there is only the 6w and a 21w bulb as far as I know... the 6w is the feeble bulb that LR's fitted and the 21w causes meltdown..... I not sure if you can get LED bulbs that will plug straight in, as the base of the bulb isn't standard, it has offset pins, just to be awkward Evil or Very Mad
That is was so many of u8s have gone the LED panel route, which gives the best results Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #413545 14th Nov 2016 4:10pm
as Paul says, everything has been suggested from splitting the lights and inserting cob/led panels to wiring auxiliary reverse lights under the bumper...
to get any decent light output you will have to be prepared to do some fettling... ... - .- -.
Post #413548 14th Nov 2016 4:14pm
miggit
fettling?? Shocked
Whistle I prefer to prise the light apart with a STANLEY Shocked Shocked Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #413549 14th Nov 2016 4:17pm
very sharp Mr. Green ... - .- -.
Post #413550 14th Nov 2016 4:19pm
miggit
Bow down It's not often that you can claim to be the sharpest tool in the box Thumbs Up
I have just come across these http://www.ebay.co.uk/itm/2x-Land-Rover-Ra...SwuAVWyChr It doesn't say what wattage they are... so it's up to you if you chance them... But I personally can't see them being any brighter that std.
But what ever you get it needs to a H6W or BAX9S base, otherwise it wont fit, and nothing that's much wider than the base... cos it's a tight fit Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #413552 14th Nov 2016 4:26pm
smartone
Thank you very much for the replies!
I had hoped that we'd moved on from cutting and reshaping the fittings etc.
Cheers though!!
Post #413553 14th Nov 2016 4:32pm
smartone
put in my car and it says that they fit.
I called them and they said, no, they will not fit.
Can someone maybe tell me the simplest "DIY" job that I would need to do. I'm good with electrics if its a bit of soldering etc....for my 2011 RR.
Cheers again
Post #413554 14th Nov 2016 4:35pm
smartone
sorry I meant that I entered the model of my car into the ebay tool and was told that they were suitable, but upon calling them I heard that they did NOT fit my car.
Soz
Post #413555 14th Nov 2016 4:40pm
miggit
I suspect that they don't fit because its a tight squeeze to get the bulb in the lens, the hole isn't too big.... that is not to say that the hole can't be made bigger Whistle
These look like they will give more output than that first lot http://www.ebay.co.uk/itm/2X-10-SMD-LED-43...Sw9NdXvmKu But it more than likely need the hole opening up in the lens so that the bulb can pass through. Oh and they don't have to be canbus... the reverse lamps are not in the LCM, so no messages Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #413559 14th Nov 2016 4:53pm
you could take off the OE reverse light and replace the whole thing with something like this ,
theres loads of these types of lights on ebay and if you find the right one and with a bit of fettling you could end up with a much brighter and smaller light unit..
a project for you maybe Paul.. Wink ... - .- -.
Post #413567 14th Nov 2016 5:36pm
smartone
Does anybody think these are worth trying??
http://www.ebay.co.uk/itm/2x-Land-Rover-Ra...1494292015
they don't look longer than 30mm max length to not touch the inner of the light case unit, and have a 10mm contact base and offset.
Cheers
ps apologies if suggested already, but I believe not.
Post #413897 16th Nov 2016 11:06am
miggit
I wouldn't bother, 1, I have my doubts as to whether they will go through the lens hole... and 2, they are what looks to be "normal" clear led's, I would be surprised if they are brighter than the original Rolling Eyes
The led's that have a yellow colour are COB type.. they have a much higher output, and don't worry they are white when powered up Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #413901 16th Nov 2016 12:40pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Can only be used off-road.
Reverse lights are limited to two with a maximum of 21W each for road use
Post #414073 17th Nov 2016 12:12pm
''off road'' ......and that refers to the cob panels or aux reverse lights ?.... ... - .- -.
Post #414077 17th Nov 2016 12:18pm
