Home > In Car Electronics (L322) > Timed Climate.....sometimes comes on, sometimes doesn't
smartone
2003 Range Rover Autobiography 4.4 V8 Java Black
Anyone any ideas why some mornings the car heats nicely, but some mornings it just stays asleep. It makes me feel as if I'm doing something wrong. Does it need to have the "AIRCON" button on when shut down the following evening, or the temperature set to full heat....
It's quite simple really. Timed climate works some mornings and not others. And no, I am allowing for the feature to turn off if the car isn't used for two days, like the weekend.
Or is this a proper intermittent electrical fault that will show with plug in JLR diagnostics?
Cheers
Post #413471 14th Nov 2016 10:11am
Dave
I think i may have something to do with the battery status, i find if im only doing short trips in the week then the battery wont have time to charge, and mine wont work, but if i do a good few trips, then no problems, it may just be circumstantial Dave
2012 Vogue Westminster 4.4
Post #413502 14th Nov 2016 1:02pm
smartone
Thanks for that.
I do many decent runs during the week and weekend, so I'm not sure about the battery unless its on its last legs. The battery and car is 5 years old now??
Cheers
Post #413507 14th Nov 2016 1:49pm
Dolphinboy
You do need to have the heating turned up (see Stan's posts about this) and the ambient temp outside needs to be below stg like 15*
Post #413512 14th Nov 2016 2:15pm
Dolphinboy
see wiki
http://www.fullfatrr.com/wiki/FBH
Post #413514 14th Nov 2016 2:17pm
smartone
Thank you I shall try this tonight.
Regards
Post #413519 14th Nov 2016 2:52pm
Rob99
I'm sure I read somewhere too that it won't work when the fuel is low, although I don't know how low, possibly when it says "low" Rolling Eyes Rolling Eyes 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #413520 14th Nov 2016 3:04pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Not sure you need heating turned up in a 2003 model.
Need battery power. Temp less than 15. More than 7.5 litres of fuel.
Then all should be good. Engine coolant of course needs to be below a certain temp too.
Post #413764 15th Nov 2016 7:23pm
smartone
Been and had it checked out.
This is a recognised fault (bulletin) and develops as the battery ages. The timed climate is coming on but it's not staying on for as long as it should.
According to JLR, they've solved the issue with a new AGM battery, a new power lead and a software update to cope with the new battery management.
A half job would just replace the 5 year old battery with a new one, as this would probably do the job for a few years, but I think I'll opt for the new AGM battery, power lead and software update. May as well do it properly for next owner!
Post #414673 21st Nov 2016 5:34pm
