![]() | Home > Technical (L322) > Radiator Drain plug removal 3.0 litre Diesel |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
From memory......
Roverlord Member Since: 19 Aug 2016 Location: london Posts: 29 ![]() ![]() ![]() |
Thanks for the reply, he I know where it's located, I have removed the bottom tray and looked up, but how to you get to it, there doesn't seem to be much room to get your arm and and in. Do you have to dismantle other things to get to it? id there an easy way?
I managed to get at it without removing that hose, I think i went in from the middle of the car and reached over that pipe. However if it makes it easier for you that hose can be removed as it's the intercooler pipe and only carries air |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 166 ![]() ![]() ![]() |
must able to reach it, BUT....be prepared that it will brake off! |
Yes I know the plugs aren't expensive, and have a replacement on hand. Looks like the inter cooler hose needs to come off then.
Kaitsu Member Since: 16 Dec 2018 Location: Nurmijarvi Posts: 1 ![]() ![]() |
I have the drain plug cap (red) broken also, so I would need to get the rest of the plug extracted from the sleeve. I wonder if that sleeve is threated to rad or fixed? It would be easy to screw that sleeve off and then work on the plug when in vice.
