Home > Technical (L322) > Popping and crackling sound |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3167 |
Check the wiring is properly connected to the speakers in the doors. Sometimes they can be broken off or loose. Also check for corrosion on the spikes/tongues on the plugs into the amp. Sometime a toothbrush and bit of electrical contact spray can work wonders. |
11th Nov 2016 10:52pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'd also make sure that its not all drowning... check the boot for water (under the floor) .. the tailgate seal isn't the best and the sunroof drains can get blocked too Yesterday I couldn't spell Engineer... Today I are one!
12th Nov 2016 1:46am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1656 |
Could it also be external interference? Does it happen anywhere or just somewhere? I get similar symptoms when driving in one particular area. 405 AB exec seats Baltic and Cirrus
12th Nov 2016 11:07am |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
Thanks for the replies:
12th Nov 2016 6:20pm |
think I'd be looking at the sunroof drains.. and they are under the sill Yesterday I couldn't spell Engineer... Today I are one!
12th Nov 2016 11:13pm |
Paddyc Member Since: 30 May 2016 Location: Antrim Posts: 13 |
hi stormin
16th Oct 2017 10:34pm |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
Strong chance it is the tailgate seal letting in water....thats what mine was doing.
17th Oct 2017 7:20pm |
Closerthanmost Member Since: 27 Aug 2017 Location: Cambridgeshire Posts: 62 |
This has just happened to mine too.
20th Oct 2017 5:41pm |
Thanks cooper- going to give mine a really close inspection this weekend
21st Oct 2017 1:13pm |
The tailgate seal is notorious for letting in water and dumping it over the I.C.E and Nav equipment in the boot, mine filled up the cubby hole with about 3" of water before it all went POP
22nd Oct 2017 12:33am |
No worries Paddy.
24th Oct 2017 8:53am |
