Home > Technical (L322) > Heated seat doesn't work until engine restarted
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
So i've had this a few times in the past week now. Get in the car stick the heated seat on and nothing happens.
However, the next day it starts working again?
At first I did a quick search on here and thought perhaps the fan is gone or the plastic piping is split, but apparently not.
In traffic this morning with a freezing bum i decided id turn off the engine and restart it, as soon as i restarted the heated seat came back on and stayed on and hot for over an hour after, so it surely cant be split piping or anything to do with the heating element itself, right? Must be a control module?
The LED's on the heated seat button stay on as usual...
Just wondering if anyone has had this exact problem. Obviously many people realising their heated seats don't function now the weather is getting cold Laughing Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #413065 11th Nov 2016 10:37am
this might be one of the quirks of owning a FF..
yesterday i couldnt select any of the radio options on the touchscreen even though they beeped when clicked..stopped , restarted and all was well again..
i think its down to the cold and the battery not being 100% ,cos after a run and the battery has had a charge everything works ok ... - .- -.
Post #413066 11th Nov 2016 10:48am
JPHC
Yes maybe it is Stan Big Cry
Annoying though because I've just had a new battery and use the heated seat almost everyday and never once had this issue up to the past week! Jordan
'56 SC 4.2 ‘16-‘18
Post #413067 11th Nov 2016 10:53am
Dolphinboy
Stan, have you tried using your fingers instead of your tongue? Rolling with laughter Whistle Mr. Green
Post #413068 11th Nov 2016 11:07am
Until you have a look at the Peltier cell and read the codes you won't know anything for sure ,it could be that you moved and closed the pipe up a bit . Nearly always goes intermittent when it starts to fail . 2008 MY Supercharged
Post #413070 11th Nov 2016 11:29am
i can 'c' what i did there.. Embarassed Laughing
edited.. ... - .- -.
Post #413074 11th Nov 2016 11:51am
JPHC
Ok, yeah i did move the seat all the way back and all the way fordward last week so could potentially be related. Guess i need to do a visual check then get it scanned. Need an IID tool Whistle Jordan
'56 SC 4.2 ‘16-‘18
Post #413101 11th Nov 2016 5:25pm
JPHC
Update
Ok so I got an IID Tool and did the scan. I got the attached image:
Assuming this means the fan is overheating because of a damaged/loose piping and the pressure. So my next question is, how much of a job is it to trouble shoot this and replace the necessary part Big Cry Big Cry Jordan
'56 SC 4.2 ‘16-‘18
Post #414010 16th Nov 2016 11:11pm
supershuttle
Mines a bit funny, sometimes it works sometimes it doesn't. I can tell immediately by feeling under the seat to see if the fan is spinning - if it is it works if it isn't it doesn't - generally a restart sorts it. Geoff
Post #414016 17th Nov 2016 12:15am
JPHC
Interesting Geoff. How long has yours done that?
Had mine 6 months / 12k miles and it only started a few weeks ago from what I can tell, so not sure it's just a quirk.
Thing is if it really was damaged piping/pressure drop causing the fans to over hear, why would a restart fix it? Question Jordan
'56 SC 4.2 ‘16-‘18
Post #414017 17th Nov 2016 12:19am
