Home > Technical (L322) > Heated seat doesn't work until engine restarted |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 |
So i've had this a few times in the past week now. Get in the car stick the heated seat on and nothing happens.
11th Nov 2016 9:37am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35249 |
this might be one of the quirks of owning a FF..
11th Nov 2016 9:48am |
Yes maybe it is Stan
11th Nov 2016 9:53am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3130 |
Stan, have you tried using your fingers instead of your tongue? |
11th Nov 2016 10:07am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Until you have a look at the Peltier cell and read the codes you won't know anything for sure ,it could be that you moved and closed the pipe up a bit . Nearly always goes intermittent when it starts to fail . 2008 MY Supercharged
11th Nov 2016 10:29am |
i can 'c' what i did there.. edited.. ... - .- -. Y. O. L. O. . |
11th Nov 2016 10:51am |
Ok, yeah i did move the seat all the way back and all the way fordward last week so could potentially be related. Guess i need to do a visual check then get it scanned. Need an IID tool Jordan
11th Nov 2016 4:25pm |
Ok so I got an IID Tool and did the scan. I got the attached image:
16th Nov 2016 10:11pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3766 |
Mines a bit funny, sometimes it works sometimes it doesn't. I can tell immediately by feeling under the seat to see if the fan is spinning - if it is it works if it isn't it doesn't - generally a restart sorts it. Geoff |
16th Nov 2016 11:15pm |
Interesting Geoff. How long has yours done that?
16th Nov 2016 11:19pm |
