Home > Technical (L322) > cleaning throttle body |
Aerosol carburettor cleaner. Works like a champ but don't get it on your skin as it removes all the oils and you go very white and powdery. |
10th Nov 2016 9:35am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Perfect! Shall aquire some today |
10th Nov 2016 9:38am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
just did mine, I used tooth brush with some diesel and finish with degreaser spray. 35-40 min job. |
10th Nov 2016 1:23pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8164 |
Be careful, you can ruin a throttle body if you open the flap against the motor, IMHO it is a total waste of time on a petrol, yes it will have dirt on it but it's a drop in the ocean, the whole inlet tract has the same film of dirt on it and nobody bothers to clean the entire inlet manifold....
10th Nov 2016 3:25pm |
That's good enough for me..leave well alone and go through the list of other possibilities..firstly I have been using morrisons unleaded. Will use another source for her, changing battery at the weekend as its suspect then I will have a read up on everything else...don't really trust my icarsoft for data streams now as I'm certain its giving me dodgy readings so iid tools a priority first.thanks again Pete... |
10th Nov 2016 5:09pm |
