Home > Technical (L322) > TD6 MAF
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
TD6 MAF
Tried the other day to take off only the Maf sensor for cleaning it but screws holding the sensor on maf body,at least to my car, are quite peculiar.Both head of the screw and the hole in the center of the head are completely rounded.So typically cannot be unscrewed without damaging them unless if there is any special tool or simply the sensor cannot be separated from the maf body?
Any ideas ?????
Post #412665 8th Nov 2016 4:02pm
Possibly a security Torx bit
Post #412692 8th Nov 2016 8:07pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
It is possible to get them out with a pair of long nose pliers if you are stuck, just takes a few goes to get enough purchase on the thin edge of the screw head. I always swap them for standard head screws, they only go into plastic so self tappers do the job. All Bosch mafs seem to be the same, never understood why security screws are needed.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #412737 9th Nov 2016 8:44am
AKIS
Thanks for your replies.Just wanted to ensure that i can separate maf sensor from body.Believe will manage to find a way to to do it even by damaging screws head which i will substitute with a more common type.
Post #412785 9th Nov 2016 12:51pm
AKIS
Finally maf removed without damaging screws.Needed tool 5 sided security torx/star instead of the usual one with 6 edges?
Post #414906 23rd Nov 2016 11:56am
