Home > Technical (L322) > Coolant? |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Hi Guys
6th Dec 2010 7:37pm |
Rads can be had from £140+Vat http://www.lrseries.com/shop/product/listi...ml?limit=0
6th Dec 2010 8:14pm |
I have the pink/orange coolant. What's the difference in color? Can the pink stuff come in blue/green or is it a standard system all manufacturers use? |
6th Dec 2010 10:05pm |
That's the longlife "Organic" coolant. If you mix it with any other type it forms a thick sludge... Personally I dislike it because you cant buy it everywhere and if you need a top up in a service station you will more than likely only find blue. It's also fairly expensive in comparison to plain.
6th Dec 2010 10:53pm |
Glad I made you cry! Seems if you mix the pink with the blue you end up in the brown! Lol |
7th Dec 2010 12:14am |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 |
I bought the Halfords Advanced coolant as a top up earlier this year with no problem.
7th Dec 2010 6:05am |
As long as you mix that with existing red coolant then you will be fine. If you have mixed it with blue you will have a problem, you just haven't noticed yet. It's one of the causes of the blocked lower pipes in the rad which causes trans overheats. |
7th Dec 2010 9:10am |
