Home > Technical (L322) > Coolant?
Coolant?
Hi Guys
I've been loosing a bit of coolant for a while and dreading it could be HGF but after dropping my sidelight retaining nut in the cold, discovered a few drips of coolant from front left. I'm assuming it's the rad. Im guessing this is an easy fix? Also do we have a special coolant in our beasts? Where is the best place for a new rad and coolant?
Thanks
Rob
Post #41188 6th Dec 2010 7:37pm
dan_uk_1984
Rads can be had from £140+Vat http://www.lrseries.com/shop/product/listi...ml?limit=0
It's not the most difficult job to do, although you'd be wise to have a copy of the workshop manual to hand.
If you have standard green/blue coolant then you're generally safe to use most off the shelf coolants. If you have red/pink/orange you need to be carefull because you cant mix and match without hardcore flushing.
Post #41197 6th Dec 2010 8:14pm
I have the pink/orange coolant. What's the difference in color? Can the pink stuff come in blue/green or is it a standard system all manufacturers use?
Post #41227 6th Dec 2010 10:05pm
dan_uk_1984
That's the longlife "Organic" coolant. If you mix it with any other type it forms a thick sludge... Personally I dislike it because you cant buy it everywhere and if you need a top up in a service station you will more than likely only find blue. It's also fairly expensive in comparison to plain.
That being said its service interval is meant to be longer - although if you have corrosion already causing a leak then perhaps that's not so true.
Maybe someone with more authority on the subject will post...
Post #41240 6th Dec 2010 10:53pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I'm sorry..... but this made me cry Laughing Rolling with laughter Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #41242 6th Dec 2010 11:10pm
Glad I made you cry! Seems if you mix the pink with the blue you end up in the brown! Lol
Post #41259 7th Dec 2010 12:14am
ukrangie
I bought the Halfords Advanced coolant as a top up earlier this year with no problem.
http://www.halfords.com/webapp/wcs/stores/...yId_229902 Paul
Twitter - Facebook
Post #41265 7th Dec 2010 6:05am
dan_uk_1984
As long as you mix that with existing red coolant then you will be fine. If you have mixed it with blue you will have a problem, you just haven't noticed yet.
It's one of the causes of the blocked lower pipes in the rad which causes trans overheats.
Post #41276 7th Dec 2010 9:10am
