Home > Technical (L322) > Heated Washer Jets |
Do you have a strong mix of anti-freeze washer fluid? the 10% dilution often only goes down to -2 to -5 but. So although the jets are thawed you can get ice in the tank that causes blockages.
6th Dec 2010 8:21pm |
6th Dec 2010 8:23pm |
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 |
Hi Dan, It's got 2 litres of concentrate in there but I'm not sure of the tank capacity. I got the link you posted thanks, but obviously these will take time to arrive so was wondering if there was a way of checking them first, does the jet get physically warm on the pipe perhaps? S |
6th Dec 2010 8:27pm |
The only test I think you could do is a continuity test?
6th Dec 2010 8:37pm |
Brand new battery on Saturday, need to get a new multimeter this weekend then I can test that MOT on Thursday so will get it checked then along with the faulty FBH. Thanks Dan S |
6th Dec 2010 9:58pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Been in temperatures down to -9c tonight, just poured neat screen wash into bottle. Works so far... |
6th Dec 2010 10:47pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I've never understood why the washer bottles don't have heaters for adverse conditions (and also some sort of heatable wire in the washer pipes). You can buy kettles that plug into a cigarette lighter so don't know why a manufacturer hasn't come up with an element moulded into a washer bottle. Seems daft to have heated nozzles when the water/screen wash is frozen in the pipe behind it! I was looking for concentrated screen wash last week and the lowest it goes to is -6 degrees and thats if it is 100% screen wash with no water (that was around £3.89 for 1 litre) so reckon it would end up costing more than diesel to keep the washer bottle filled with that!! Steve
9th Dec 2010 10:44am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
i think manufacters rely on the heat from the engine to warm the washer bottle and pipes.. ... - .- -.
9th Dec 2010 12:46pm |
Well no amount of heated washer jets was stopping mine from freezing, and I used 100% screen wash.
9th Dec 2010 12:50pm |
i found the inside cabin temperature very comfortable on a recent trek to brussels, didnt want to get out .. ... - .- -.
9th Dec 2010 1:17pm |
Agree, interior was always toasty on my trip |
9th Dec 2010 1:27pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Problem sorted then, route the washer tube through the cabin. |
9th Dec 2010 1:30pm |
I'm sure a kit was available, that was basically wrapping the washer tube around a heater hose to warm water up. Could have been interesting, hot water on cold windsreen! |
9th Dec 2010 1:33pm |
maybe that's why the manufacters don't do this, hot water on a cold windscreen will cause untold problems.. ... - .- -.
9th Dec 2010 3:04pm |
