Home > Technical (L322) > Heated Washer Jets
Page 1 of 4 1234>
GJOB
2005 Range Rover Vogue SE Td6 Java Black
Heated Washer Jets
If these are working correctly does the washer fluid ever fail to come out?
Driving in the freezing fog tonight they stopped working making it rather dangerous to see where I was going. Shocked
Post #41196 6th Dec 2010 8:14pm
dan_uk_1984
Do you have a strong mix of anti-freeze washer fluid? the 10% dilution often only goes down to -2 to -5 but. So although the jets are thawed you can get ice in the tank that causes blockages.
I posted somewhere else with a link to the heated washer jet - they are only £6.00. Part # is DNJ000010
Dan
Post #41200 6th Dec 2010 8:21pm
http://www.fullfatrr.com/forum/topic3935.html Thumbs Up
Post #41201 6th Dec 2010 8:23pm
GJOB
Dan
Hi Dan, It's got 2 litres of concentrate in there but I'm not sure of the tank capacity.
I got the link you posted thanks, but obviously these will take time to arrive so was wondering if there was a way of checking them first, does the jet get physically warm on the pipe perhaps?
S
Post #41204 6th Dec 2010 8:27pm
dan_uk_1984
The only test I think you could do is a continuity test?
The WSM does say that if battery voltage drops below 11.4V. Are you driving with the heated seats/screens/wheel on along with lights and blowers etc? I'd worry if the alt couldnt keep up though... May be worth a check?
Post #41206 6th Dec 2010 8:37pm
GJOB
Brand new battery on Saturday, need to get a new multimeter this weekend then I can test that Thumbs Up
MOT on Thursday so will get it checked then along with the faulty FBH.
Thanks Dan Thumbs Up
S
Post #41226 6th Dec 2010 9:58pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Been in temperatures down to -9c tonight, just poured neat screen wash into bottle. Works so far...
Post #41239 6th Dec 2010 10:47pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I've never understood why the washer bottles don't have heaters for adverse conditions (and also some sort of heatable wire in the washer pipes). You can buy kettles that plug into a cigarette lighter so don't know why a manufacturer hasn't come up with an element moulded into a washer bottle. Seems daft to have heated nozzles when the water/screen wash is frozen in the pipe behind it! I was looking for concentrated screen wash last week and the lowest it goes to is -6 degrees and thats if it is 100% screen wash with no water (that was around £3.89 for 1 litre) so reckon it would end up costing more than diesel to keep the washer bottle filled with that!! Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #41557 9th Dec 2010 10:44am
i think manufacters rely on the heat from the engine to warm the washer bottle and pipes.. ... - .- -.
Post #41576 9th Dec 2010 12:46pm
Richcl
Well no amount of heated washer jets was stopping mine from freezing, and I used 100% screen wash.
Temperatures were as low as -13 in Scotland, and coming home on motorway + cold temps made the washers freeze up. Had to pull off the motorway several times and let heat from engine thaw washers out.
Post #41577 9th Dec 2010 12:50pm
i found the inside cabin temperature very comfortable on a recent trek to brussels, didnt want to get out .. ... - .- -.
Post #41584 9th Dec 2010 1:17pm
Richcl
Agree, interior was always toasty on my trip Very Happy
Post #41587 9th Dec 2010 1:27pm
Fox
Problem sorted then, route the washer tube through the cabin. Wink
Post #41589 9th Dec 2010 1:30pm
Richcl
I'm sure a kit was available, that was basically wrapping the washer tube around a heater hose to warm water up. Could have been interesting, hot water on cold windsreen! Shocked
Post #41590 9th Dec 2010 1:33pm
maybe that's why the manufacters don't do this, hot water on a cold windscreen will cause untold problems.. ... - .- -.
Post #41598 9th Dec 2010 3:04pm
Page 1 of 4 1234>
