Home > Technical (L322) > 4.4 tdv8 12MY reluctance to start |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 |
anyone else experience this:
21st Oct 2016 8:17pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
Starter solenoid needing to be replaced/repaired? John
21st Oct 2016 8:22pm |
or SM are my thoughts but keep wondering if it isint something else not allowing it to go! Cheers
21st Oct 2016 8:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35338 |
was the battery fitted before or after this problem.....if before are all the battery connections tight.. ... - .- -.
21st Oct 2016 8:44pm |
i had this problem with new vehicle as it came so on thrid day replaced the battery, no change Cheers
21st Oct 2016 9:05pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1425 |
Who did you buy it from? If it was a dealer then they should sort it out. 2021 D350 Fifty Edition - Carpathian Grey
22nd Oct 2016 7:40am |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 |
Hi James
22nd Oct 2016 10:17am |
its going in tue to be looked at by dealer.
27th Oct 2016 10:22am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
James, I had this same problem on my 2011 tdv8 when I was a year old. Dealer fitted a ew starter motor at that time and I had no further problems for the next 2 years which I had the car. I believe it is a known fault and has been raised on here in the past. Agueroooooooooo. 93-20
27th Oct 2016 10:58am |
thats nice to hear, well sort of! i am hoping that it will replicate the fault at the dealers and they can find the problem if ^^is the case then it should be easier to convince them there is a problem if it doesn't actually replicate it when they have it.
27th Oct 2016 11:02am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2567 |
Likewise, a new starter under warranty. Annoying when it won't start when you're about to drive off the Eurotunnel though. |
29th Oct 2016 2:37pm |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 |
Precisely the same problem with m 2012 TDV8 and wife brought it into the dealer yesterday.
1st Nov 2016 6:31pm |
mine goes in tomorrow! Cheers
1st Nov 2016 7:11pm |
Update: new starter motor. Apparently fully covered labour and parts money wise.
2nd Nov 2016 12:34pm |
