Home > Maintenance & Mods (L322) > Megaflush in London
Paddy
England 2007 Range Rover Vogue TDV8 Java Black
Megaflush in London
Hello to all.
I am new to the forum and after several years of being a LR fan and owner i have finally upgraded to a 2007 Range Rover.
I like to keep my cars in good order and often find that owner forums are the best place to keep informed so i hope to continue with this.
The car is in good condition with 70k on the clock. I have been reading that a flush of the transmission has been recommended by many owners despite LR saying that the sealed unit is good for life. The process i have seen mentioned a lot is called a Megaflush. The theory behind it seems very good but when i looked into having this done i have failed to find anywhere local (London) that offers the service.
Are any of you aware of a place that offers this service. I am based in Croydon so south London is preferred but i am happy to travel for a decent service.
How many of you have had this procedure carried out on your cars, is it a good idea and what should i expect to pay.
Thanks in advance for your help.
Post #393572 29th Jun 2016 7:49am
sako243
Challenger 4x4 in Surrey are a respected garage. There's a Land Rover garage in Peasmarsh but they've recently been taken over by Hunters so no idea what they're like now. I seem to remember members here recommend Lookers in Park Royal as well.
No idea on cost but I did mine myself and the oil isn't cheap, you need an absolute minimum of about 14 litres for a double flush and the cheapest I've seen is Island 4x4 at about £12 per litre. Takes a couple of hours I would think if you know what you're doing and have the kit. Ed
Post #393583 29th Jun 2016 9:29am
Dave
Found this on the forum Paddy, hope it helps Smile
http://www.fullfatrr.com/forum/topic21456.html Dave
2012 Vogue Westminster 4.4
Post #393584 29th Jun 2016 9:52am
Paddy
£615 including VAT and filter change.Does that sound reasonable?
Post #410628 25th Oct 2016 10:29am
No, extortionate.... Thumbs Up Pete
Post #410632 25th Oct 2016 11:14am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
My Indy is from £250. Not sure what extras you can add but it does show that Haylands is absolutely correct. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #410633 25th Oct 2016 11:17am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Could try http://www.bespokeautostyling.com
i am pretty sure they do it.
DrF
Post #410635 25th Oct 2016 11:20am
rangie47
my local indy charges 260 2007 tdv8 se ,stornaway grey
Post #410676 25th Oct 2016 8:24pm
Paddy
What are they called? It may be worth the drive if they are recommended. Only 20 miles away.
Do they flush or just drain and refill?
Post #410723 26th Oct 2016 8:28am
V8Noise
Mines close to Hastings so probably a bit far. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #410735 26th Oct 2016 11:27am
