Home > Technical (L322) > Air Susp. Inactive. Blackbox solutions. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8269 |
It will be a failing height sensor, they sometimes give you a bit of warning with that fault before they die completely...
23rd Oct 2016 9:08am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Also, if away from home, suggest you don't clear the fault, (if the height sensor has "broken") as the suspension may drop to the bump stops, leaving for an uncomfortable ride home! ( If driveable?)
23rd Oct 2016 11:29am |
Tim, if it happens again, go into service/test and you can raise the corners manually, this locks the EAS off so it stays at that height, then replace the sensor at leisure and turn the EAS back on with the IID.... That's why it's the best tool... Pete
23rd Oct 2016 2:50pm |
