Home > In Car Electronics (L322) > Reverse camera repair / upgrade
Page 2 of 7 <1234567>
forever
btw, does anyone know if you can a cable that plugs directly into the signalin brass housing and then has a RCA plug attached? would save messing with the soldering iron
Post #408153 7th Oct 2016 4:09pm
Kinch
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Okay, I'm indicating with the wire cutters, which location do I want to cut? Right behind the camera, or just before the yellow and red connectuons?
Post #408208 7th Oct 2016 8:17pm
Angus_bull
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Java Black
Don't cut any wires off the camera especially close to the camera as there is a small power convertor inside the large moulded plastic half way along the cable. I did this with my first camera and wrecked it.
I'm not sure how much your new camera will strip down but I don't think that one will work. As part of the camera pack, you should have received a power cable and a yellow phono cable, these need to be attached to the original camera lead to act as a harness. It can all be plugged in as one then. If you let me know what the colour of the four original wires are then I can tell you what needs to be connected (if I can remember)
Here is the camera that I bought, I then unscrewed the front part and was left with this
I trimmed the front part and screwed it back on then put it in the housing
For the loom I connected the power and signal cables together and added heat shrink to tidy it up
Lastly, excuse any spelling mistakes as I'm typing this on a tablet
Post #408897 11th Oct 2016 9:38pm
Angus_bull
One more think, you will need to dig out all the old resin from the rear of your old camera casing and drill it large enough (12mm if I recall) for the plugs and large moulded section to pass through. These will also go through the spoiler fine if you remove the riveted holder then refit.
If this all goes successfully, then it is a good idea to seal the camera housing up properly with silicone as I ended up with a bit of water in mine after a few week which resulted in a blurry picture. Again make sure the camera works fine before doing this as it will be a pain to dig all the silicone back out if you don't like it.
Have a good search through the forum as there are a few posts on this and a good one in the wiki.
Post #408899 11th Oct 2016 9:45pm
Kinch
Angus thanks for the post. Before you made it, I did the job wrong and ruined my camera. I'm trying to wire it back to see if it will at least work. I'm going to post some photos to show you what I did.
Post #409013 12th Oct 2016 12:53pm
forever
Good luck with that, i did the same first time as i did not think the plugs would fit through the hole in the spoiler, tried to wire it back but gave up, they only cost around £8.00, so i would buy another..
Post #409015 12th Oct 2016 12:57pm
Kinch
Okay Angus, so here are pictures of how I did it the wrong way lol. I also took a dremel to the camera and made it smaller in diameter so it would fit in the original housing. Anyway check it out.
Post #409041 12th Oct 2016 4:44pm
forever
I am still struggling with getting a connect via the yellow rca cable, i have cut it and it give a black and red wire, on my test bench both need to be connected to get an image on a tv, but the rangerover loom only has the coaxial type connection how do you connect that in ? Or can you buy and adaptor to plug from the yellow rca cable into the brass coaxial type?
Post #409283 14th Oct 2016 11:41am
stucart
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Mine has got the black screen of death also after some intermittent working, notice there is condensation in the housing so ive ordered one off Ebay to try this fix also, any more info about soldering the new camera leads to the original camera leads would be useful, as I understand going from the new camera to the coax type connection looks tricky??
Post #409943 20th Oct 2016 11:48am
themule
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
My new camera has now arrived, it's a different design to these though (it has 6 LEDs for night time reversing) and I have taken it apart with the idea of just replacing the circuit board / lens. It has 3 wires coming out, +ve, ground and video. There are 4 wires into the old camera, 2 power, the others presumably being video and the shielding for the coax - not sure how to 3 into 4 goes .
Maybe I will get the round camera and do what Nick did.
Post #410051 20th Oct 2016 8:59pm
themule
I am missing something here. The cameras have 3 wires, 2 power and the composite signal. I don't see how the single composite signal wire connects to the SMB (coax) cable that has two connections.
Post #410195 21st Oct 2016 7:26pm
the earth on the power doubles up as the shielding on the coax..[if that makes sense] ... - .- -.
Post #410202 21st Oct 2016 8:10pm
themule
Thanks Stan. So The black earth wire splits, 1 bit for the shielding and 1 for the power earth? That would explain the moulded part on the new cable, which I cut off.
Post #410214 21st Oct 2016 8:53pm
thats what i've found when doing my home cctv .. ... - .- -.
Post #410215 21st Oct 2016 8:55pm
n1cktdv8
I did only a minor trim on the bezel at the focal end of the unit. It then went into the existing housing with no fuss and after it was aligned and shimmed, I back filled it with silicone and allowed it to set.
There is no direct plug and play, I soldered the neg to the shield and it's working just fine. I used heat shrink and insulation tape to ensure it is protected.
A bit gung ho for some of you more refined but I needed the camera! Is this where I put the car details and a bit about myself ?........
Post #410217 21st Oct 2016 9:06pm
