Home > In Car Electronics (L322) > Reverse camera repair / upgrade |
Kinch Member Since: 08 Aug 2016 Location: Idaho Posts: 45 |
Okay, I'm indicating with the wire cutters, which location do I want to cut? Right behind the camera, or just before the yellow and red connectuons?
7th Oct 2016 8:17pm |
Angus_bull Member Since: 17 Apr 2015 Location: Fauldhouse Posts: 7 |
Don't cut any wires off the camera especially close to the camera as there is a small power convertor inside the large moulded plastic half way along the cable. I did this with my first camera and wrecked it.
11th Oct 2016 9:38pm |
One more think, you will need to dig out all the old resin from the rear of your old camera casing and drill it large enough (12mm if I recall) for the plugs and large moulded section to pass through. These will also go through the spoiler fine if you remove the riveted holder then refit.
11th Oct 2016 9:45pm |
Angus thanks for the post. Before you made it, I did the job wrong and ruined my camera. I'm trying to wire it back to see if it will at least work. I'm going to post some photos to show you what I did. |
12th Oct 2016 12:53pm |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
Good luck with that, i did the same first time as i did not think the plugs would fit through the hole in the spoiler, tried to wire it back but gave up, they only cost around £8.00, so i would buy another.. |
12th Oct 2016 12:57pm |
12th Oct 2016 4:44pm |
I am still struggling with getting a connect via the yellow rca cable, i have cut it and it give a black and red wire, on my test bench both need to be connected to get an image on a tv, but the rangerover loom only has the coaxial type connection how do you connect that in ? Or can you buy and adaptor to plug from the yellow rca cable into the brass coaxial type? |
14th Oct 2016 11:41am |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 |
Mine has got the black screen of death also after some intermittent working, notice there is condensation in the housing so ive ordered one off Ebay to try this fix also, any more info about soldering the new camera leads to the original camera leads would be useful, as I understand going from the new camera to the coax type connection looks tricky?? |
20th Oct 2016 11:48am |
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 |
My new camera has now arrived, it's a different design to these though (it has 6 LEDs for night time reversing) and I have taken it apart with the idea of just replacing the circuit board / lens. It has 3 wires coming out, +ve, ground and video. There are 4 wires into the old camera, 2 power, the others presumably being video and the shielding for the coax - not sure how to 3 into 4 goes .
20th Oct 2016 8:59pm |
I am missing something here. The cameras have 3 wires, 2 power and the composite signal. I don't see how the single composite signal wire connects to the SMB (coax) cable that has two connections. |
21st Oct 2016 7:26pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
the earth on the power doubles up as the shielding on the coax..[if that makes sense] ... - .- -.
21st Oct 2016 8:10pm |
Thanks Stan. So The black earth wire splits, 1 bit for the shielding and 1 for the power earth? That would explain the moulded part on the new cable, which I cut off. |
21st Oct 2016 8:53pm |
thats what i've found when doing my home cctv .. ... - .- -.
21st Oct 2016 8:55pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
I did only a minor trim on the bezel at the focal end of the unit. It then went into the existing housing with no fuss and after it was aligned and shimmed, I back filled it with silicone and allowed it to set. There is no direct plug and play, I soldered the neg to the shield and it's working just fine. I used heat shrink and insulation tape to ensure it is protected. A bit gung ho for some of you more refined but I needed the camera! Is this where I put the car details and a bit about myself ?........ |
21st Oct 2016 9:06pm |
