Home > In Car Electronics (L322) > Fuse for analogue clock
Darren9330
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Does anybody have an idea as to where it's located?
I had an aftermarket head unit fitted and the clocks (digital & analogue) are both out.
cheers
Post #408359 8th Oct 2016 9:11pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
as far as I know the analog clock is set by the radio if the radio has been removed then the clock can not set a time
Post #408378 8th Oct 2016 11:33pm
Brian
When you pull the fuse for the clock it resets back to 12 - so do it at 12 noon or 12 midnight and your clock will then be right. I don't know were the fuse is myself and never really bothered to look for it as the time is displayed on my aftermarket head unit. Also I keep forgetting about it until its after 12 Rolling with laughter
Post #408827 11th Oct 2016 7:27pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I think the analogue clock is set by the original radio, and if you've removed it the clock will start at 12 and run as normal for as long as the ignition is on, after that it will just reset to 12 every time.
I'm not absolutely sure on those facts but if you pm Haylands he should be able to set you right (no pun intended) as he did an aftermarket installation in his Range Rover.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #408834 11th Oct 2016 7:44pm
Darren9330
Cheers,
I've had all of the clock/radio fuses out and it doesn't make any difference Censored
Yes it's an aftermarket unit, was wondering if disconnecting the battery might be an option?
Post #410034 20th Oct 2016 9:08pm
Lukie
not my project but there maybe a fix for this soon for all aftermarket unit's that can no longer set the clock, i will let the owner of the project know about this thread so please keep checking from time to time
Post #411342 29th Oct 2016 10:52pm
Darren9330
Thanks Lukie, much appreciated
Post #411349 29th Oct 2016 11:31pm
