Home > In Car Electronics (L322) > Venture Cam - won't connect
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
I'm having a few issues with my venture cam. The camera is new to the vehicle and won't connect.
From what I read in the manual, to introduce a new camera, with the ignition on you put it in the docking station and close it up, the green land rover ring on the camera lights up for short time and a pop up appears on the touch screen to add the camera. I don't get the pop up and the green ring doesn't light up.
The camera switches on fine. I've tested the charging prongs in the docking station and they are working fine. If I turn the camera on so the green ring is flashing, then put it in the docking station, it turns the camera off so it will charge.
Is there something else I need to do ?
Thanks
Post #409432 15th Oct 2016 7:51pm
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
How is your Bluetooth?
I have a Venture cam but my bluetooth is knackered so it wont connect.
Post #409522 16th Oct 2016 3:50pm
n1cktdv8
I'd like to learn mopre about this as mine has never worked, that I'm aware of. I have read the wiki about a battery replacement and I can't get mine to operate or even light up so I think I need new batteries as a minimum. Is this where I put the car details and a bit about myself ?........
Post #409523 16th Oct 2016 3:55pm
Biffo
That's the problem then ! My Bluetooth is Censored and disconnected/bypassed.
Replacement module will be next on the list then Big Cry
Post #409548 16th Oct 2016 5:50pm
Biffo
Quick update on this - I took the TD6 out for its first proper run today, and after about 20 miles the venture cam suddenly connected ! I have not replaced the Bluetooth module, its still bypassed Shocked
Post #411773 1st Nov 2016 9:48pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
My cam would connect for about 30 secs and picture would appear then Cam would switch off. I didn't think it was the batteries because I could leave torch on all day. Replaced batteries ( as per wiki ) and now works perfectly Not that it gets used other than showing people Laughing 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #411795 1st Nov 2016 11:39pm
