![]() | Home > Technical (L322) > Range Rover 2003 Petrol Air Suspension Inactive |
Vanhoolt8 Member Since: 09 Oct 2016 Location: West Yorkshire Posts: 13 ![]() ![]() ![]() |
Hi luke my 2005 L322 4.4v8 has got suspension inactive and HDC inactive on the dash if I leave it overnight it goes off until I go down the road 100yds and they come back on with the ABS light, I have put my code reader on a carsoft 930 and in ABS it says precharge pump and precharge pump pressure sensor I have fitted a new pump and it is no different I have checked the plug on the precharge pump and I have got no power does the power come off the ABS block the switch in the baxk of it the faults will not clear |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
Do you offer this service for free or do you charge..??? FYI latest BT IID tool will read and clear faults on any JLR product that they cover (which is most from 2007 and some earlier) It is VIN locked for CCF editing only... It actually does more than the dedicated JLR one, and certainly more than any other tool out there, the back up and support is second to none as well... Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Vanhoolt8, more info here on your problem...
Hi Pete just bled the new pre charge pump like the link you sent me all was OK in the drive went for a run below 30MPH no problem as soon as I went up to 30 steadily all lights for suspension and orange ABS lights so I have removed the black box off the ABS block and see if I can get it repaired or pick another one up and try that, I will let you know if that cures it, Many thanks for your help keep my fingers crossed cheers Nigel |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
Hi Vanhoolt8,
Thank you Simon for that when I put my code reader on it says I have a fault on the pre charge pump and the pre charge pressure sensor and they will not clear, When I left the car overnight last night this morning I went out to it and bled the pre charge pump after doing this the internet says run steadily for a few mile and then increase speed gradually and all light and warnings should go so I went out and stayed at 20MPH for a few mile and all was fine as soon as I went up to 30MPH all ABS and suspension and HDC came on again, So I have an ABS pump coming tomorrow when I have fitted this if all is well I will let you know Keep fingers crossed If not then I will look at the alternator Once again thanks Nigel |
Hi,
Hi Simon I am using a Carsoft i930 specially for Land Rover and Jaguar |
Hi Nigel,
Cheers mate I will keep you posted thanks Nigel |
Low voltage will trip all sorts of faults but not usually the ones Vanhoolt8 has, they tend to be less specific general faults, Vanhoolt8's speed specific faults are a known issue with the BMW braking system and is pretty well documented... |
Hi gentlemen i have just put another ABS Black box on the ABS pump and now i am getting faults OXOO8A air suspension system CAN error OXOO5A Temporary system deactivate and OXOO61 Steering angle sensor initialisation and HDC Inactive is still on air suspension inactive is still on and ABS lights are still on can anyone help as i am fed up with this now every time i change something i get different faults but no cure Thanks Nigel |
Hi Nigel,
Hi Simon yes i tried the steering left to right and no different I have pu another ABS module on with the same numbers on as the old one and it came off a 2005 same year as mine so will that need re coding Cheers Nigel |
