Home > Technical (L322) > Coolant leak ?? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Please fill in your profile so we know what car you have
11th Oct 2016 7:39pm |
Stew 46 Member Since: 23 Feb 2016 Location: North cornwall Posts: 123 |
Profile sorted |
11th Oct 2016 8:03pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Am I missing something here when it comes to what vehicle ? |
11th Oct 2016 8:34pm |
It's a 07 vogue SE having a bit of a prob with profile 07 VSE |
11th Oct 2016 9:29pm |
@ holidaychicken
11th Oct 2016 9:48pm |
Well at least we know but my knowledge runs out at 2005, sorry ...
11th Oct 2016 9:49pm |
It's a 3.6 tdv8 07 VSE |
11th Oct 2016 9:57pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
I'd start with the radiator. Mine had leaked, but there was little visible evidence until I unbolted the fan shroud, eased it back and looked down the rad with a torch. Then it was obvious. Then I'd check the expansion tank, as these split. |
12th Oct 2016 7:59am |
I'll inspect later today 07 VSE |
12th Oct 2016 9:03am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Stew, as above... Rads leak, expansion tanks & caps and also the back of the engine oil cooler (the aluminium block under the oil filter cartridge) they have a habit of leaking on the firewall side through the pipework... Pop the engine cover off and closely inspect using a good torch, any staining inspect further pal |
12th Oct 2016 9:33am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Ive read thermostat housing can crack. It could have happened to mine, as service history lists a replacement being fitted by previous owner.
12th Oct 2016 9:59am |
