Home > Technical (L322) > Coolant leak ??
Stew 46
England 2007 Range Rover Vogue SE TDV8 Bonatti Grey
Coolant leak ??
Over the last few weeks I seem to be topping coolant up one a week with about just under half a pint ?? , could this be water pump ? , stew
Post #408842 11th Oct 2016 8:19pm
Please fill in your profile so we know what car you have Twisted Evil
but see here: http://www.fullfatrr.com/forum/topic39844.html
problem solved Thumbs Up .
Post #408844 11th Oct 2016 8:39pm
Stew 46
Profile sorted Thumbs Up
Post #408866 11th Oct 2016 9:03pm
holidaychicken
Am I missing something here when it comes to what vehicle ?
Post #408877 11th Oct 2016 9:34pm
Stew 46
It's a 07 vogue SE Thumbs Up having a bit of a prob with profile 07 VSE
Post #408893 11th Oct 2016 10:29pm
@ holidaychicken
Yes Twisted Evil
Process for changing the waterpump on a TD6 and a 4.4V8 is quite different, and I guess for all later models too Smile
@ stew
my link will give you an idea of what is involved, but you will need RAVE/whatever for your model/year to know fully what is required Thumbs Up
Engine type will help others to help too Wink .
Post #408901 11th Oct 2016 10:48pm
holidaychicken
Well at least we know but my knowledge runs out at 2005, sorry ...
A pressure test will normally tell you if you have a leak in the cooling system and that's a fair amount of coolant that would normally leave some sign
Post #408902 11th Oct 2016 10:49pm
Stew 46
It's a 3.6 tdv8 Thumbs Up 07 VSE
Post #408906 11th Oct 2016 10:57pm
mr_spock
I'd start with the radiator. Mine had leaked, but there was little visible evidence until I unbolted the fan shroud, eased it back and looked down the rad with a torch. Then it was obvious. Then I'd check the expansion tank, as these split.
Post #408948 12th Oct 2016 8:59am
Stew 46
Thumbs Up I'll inspect later today Thumbs Up 07 VSE
Post #408959 12th Oct 2016 10:03am
Stew, as above... Rads leak, expansion tanks & caps and also the back of the engine oil cooler (the aluminium block under the oil filter cartridge) they have a habit of leaking on the firewall side through the pipework... Pop the engine cover off and closely inspect using a good torch, any staining inspect further pal Thumbs Up
Post #408960 12th Oct 2016 10:33am
rar110
Ive read thermostat housing can crack. It could have happened to mine, as service history lists a replacement being fitted by previous owner.
I also seemed to have had a slow coolant leak. The Indy pressure tested the cooling system but couldn't find a leak. I poked a cable camera around the top of the motor but found nothing. The Indy put some kind of stop leak into the coolant which seems to have fixed the loss
I would get the cooling system pressure tested, and consider something similar. ______________________________
Post #408966 12th Oct 2016 10:59am
