Home > Technical (L322) > Help required - TD6 wont start |
Not an expert here.... on my TD6, when my in line pump failed the AA man too the pipe off the fuel filter whilst I turned the key. That proved whether fuel was getting to the front. Would that not show if it's one of the pumps or nor?
9th Oct 2016 7:26pm |
Bungy Member Since: 23 Jul 2014 Location: Dorset Posts: 7 |
It was sudden, we had just stopped at some services and then a mile down the road it cut out with a fuel injection system error. I had 1/4 tank and it went to the garage for the fuel filter and pump.
10th Oct 2016 6:48am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
You should be able to hear if the in tank fuel pump is working as it'll prime for a few seconds with the ignition on.
10th Oct 2016 7:35am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
^what he said
10th Oct 2016 7:43am |
Thanks for the replies. I'll get onto that tonight and see how she does |
11th Oct 2016 7:23am |
Just tried the relay and that works as I can hear the in line pump stop, next thing to try is the wiring for the in tank pump and the pump itself. Definitely not hearing any noisy coming from the tank area. |
13th Oct 2016 2:54pm |
Most common failure is the fuel pump just in front of the near side rear wheel. Remove the cover and with the ignition on hit the pump with a spanner or light hammer
13th Oct 2016 7:02pm |
It lives!
24th Oct 2016 2:17pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Any chance of a link for the pump that you used? Yesterday I couldn't spell Engineer... Today I are one!
24th Oct 2016 3:23pm |
25th Oct 2016 8:02am |
25th Oct 2016 8:04am |
Bookmarked Just in case Yesterday I couldn't spell Engineer... Today I are one!
25th Oct 2016 10:25pm |
