![]() | Home > Technical (L322) > heating the l322 |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Ours did that just before the head gasket blew- it was air circulating/locked in the heater matrix that meant no coolant was circulating to heat the air. Check the coolant system is bled properly. |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Just been reading about it..looks straight forward enough to bleed..cheers |
Tims 7 series guide to bleeding in meeknet- maybe a google to find it- is really good. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8549 ![]() ![]() ![]() |
An airlock would not be registered as a fault, if you have an airlock you will know about it soon enough as the pressure the system works at will soon get it out the system via the overflow cap release valve...
@ huntsman cheers will check it out and try to bleed it as a maintenance job.. |
Appears to have been air in the system..did a bleed and heatings now piping! |
Nice! Keep an eye on the coolant level - I'm replacing all of my pipes tomorrow- they're all old n' leaky |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1464 ![]() ![]() |
Dan at Duckworth (site sponsor on here) usually has the best price for the IID tool.
Brilliant |
