Home > Technical (L322) > heating the l322
alistairh
heating the l322
Hi..air suspensions working beutifully so its on to my next task...cars only blowing cold air..icarsofts telling me I have 3 faults but doesn't tell what they are? Maybe time to get a proper diagnostic so recommendations welcome Wink Anyhoo clear the faults but they keep coming back and its frustrating not knowing what they are...any help is welcomed and I'm actually looking forward to solving another problem .. Thumbs Up
Post #408199 7th Oct 2016 8:22pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Ours did that just before the head gasket blew- it was air circulating/locked in the heater matrix that meant no coolant was circulating to heat the air. Check the coolant system is bled properly.
Post #408204 7th Oct 2016 8:50pm
alistairh
Just been reading about it..looks straight forward enough to bleed..cheers
Post #408207 7th Oct 2016 8:58pm
ohuntsman
Tims 7 series guide to bleeding in meeknet- maybe a google to find it- is really good.
Post #408223 8th Oct 2016 12:29am
An airlock would not be registered as a fault, if you have an airlock you will know about it soon enough as the pressure the system works at will soon get it out the system via the overflow cap release valve...
The IID is the prefered tool for all faults, it is pricey but it does more than JLR can with your vehicle and the back up and support is first rate.... Thumbs Up Thumbs Up Pete
Post #408225 8th Oct 2016 12:41am
alistairh
@ huntsman cheers will check it out and try to bleed it as a maintenance job.. Thumbs Up
@haylands that's the one I've been looking at as I've seen it mentioned in here a lot.I should have bought it first...defo need it as my current diagnostic (icarsoft) is limited in what it can do.planning on having a l322 for a while so its going to pay for itself...where did you get yours? Thanks for input Thumbs Up
Post #408240 8th Oct 2016 8:05am
alistairh
Appears to have been air in the system..did a bleed and heatings now piping! Very Happy still needing to investigate the 3 faults that are showing..iid tool is getting purchased this month! Early Xmas pressie I think.. Whistle Thanks gents!
Post #408329 8th Oct 2016 6:53pm
ohuntsman
Nice! Keep an eye on the coolant level - I'm replacing all of my pipes tomorrow- they're all old n' leaky
Post #408337 8th Oct 2016 7:42pm
Rob99
Dan at Duckworth (site sponsor on here) usually has the best price for the IID tool.
I bought the Bluetooth version, works great with an iPad. Thumbs Up Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #408409 9th Oct 2016 9:08am
alistairh
Brilliant Thumbs Up The Bluetooth one looks ideal..thanks
Post #408423 9th Oct 2016 10:24am
