Home > Technical (L322) > air suspension
Page 3 of 3 <123
miggit
I know that your getting the EAS Inactive message, is this every time you turn the key, and do you manage to get anything from the pump?
Only now you've changed the pump, have you tried going from full lock to full lock and back again? this resets the EAS, with the engine running...... there is a correct way to do this reset, but I can never remember which way to turn the wheel first, so I just go lock to lock to lock Rolling Eyes works for me Wink
There is also the battery disconnect, touch terminals and reconnect this may also help, never tried it myself, I've always managed to clear the faults with some steering wheel action Thumbs Up
I'd then be looking at the sender on the tank followed by the rear valve block.... that would appear to be where the trouble is coming from. But it's strange that it was, all be it shortly, working to a fashion and now refuses to do anything even though you've changed the pump...... Could even be a dirty connection, there were a few posts say that a good clean up underneath was all that was needed Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #407865 5th Oct 2016 10:46pm
Lock to lock:
To the left
To the right
Back to straight ahead
Thumbs Up .
Post #407870 5th Oct 2016 11:19pm
alistairh
Yeah getting the air suspension inactive everytime I turn key .did the old steering wheel reset trick as well. Going to disconnect battery after work as cars gave me more faults after I unplugged old compressor (ecu fault and a compressor exhaust one) not bothered about them as that's happened before after compressor disconnection..
So today I will double check compressors plugged in correctly Censored Battery reset plus I've just received a new relay which I will change..old one seems fine but worth a try with a renewal..if all fails then its a matter if getting under it at the weekend and check connections and give it a clean..failing that I will renew sender then valve block....only a matter if time before I crack it hahaha Banging Head
Post #407880 6th Oct 2016 6:48am
miggit
Whistle Don't hold your breath..... we'd rather you stuck around Buddy Wink
Good luck Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #407892 6th Oct 2016 7:53am
alistairh
Haha I'm here for good my friend..finally got a l322 so the invaluable advice will save me a few bob Laughing I've already learnt how the eas works and how to fault find..also fixed my unretractable mirrors and reprogrammed my key fob...great forum and some great posters as well...thanks again for the pointers Thumbs Up
Post #407908 6th Oct 2016 9:42am
alistairh
Success! Kind of Laughing unplugged compressor to check connections..Did the old battery reset.fitted second new relay ..jumps in car and starts her up..did the steering wheel reset then cleared 5 new faults then new compressor kicks in..nothing for a while but the eas message on dash doesn't reappear...then notice rear ends level and car has managed to get to access height...turn dial and car starts lifting! Getting excited now lol...car then reaches height and stops and.light stops flashing..able to lock both access and driving heights with the controls..then try's off road.cars able to reach height but wont lock after getting there...then get eas message saying compressor temp static!!
Resets fault with I carsoft and resume the up and down game...car now goes to off-road quickly but wont lock??? Apart from that zero faults ...very nearly there Thumbs Up
Post #407964 6th Oct 2016 3:39pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Great News Thumbs Up Thumbs Up Thumbs Up .
Should it lock in off road though? - I've only locked mine in access height.
When in off road it auto drops to normal if you go over a specific speed - (25mph?) Not sure Land Rover would want amy one to get around that one..
But good news anyway!!
Post #407966 6th Oct 2016 3:47pm
alistairh
Good point! My first l332 so still unsure..now to keep an eye on the air bags and hopefully no leaks then that's my first job a success...appreciate all the help especially miggits
Post #407968 6th Oct 2016 3:51pm
miggit
No worries buddy Thumbs Up
Whistle next job squirty bottle full of fairy liquid / water mix and spray away to look for any leaks.... Fyi off road position is the best for access... and when you say you cant get the off road to lock... are we talking the lock light in the middle of the switch as opposed to the high indicator that flashes as the car rises? As long as the flashing light goes solid ( can take a while for it to settle ) all should be good Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #407971 6th Oct 2016 4:01pm
alistairh
Yeah that's the one..understand now how it wont lock haha...I noticed I can see the bags whilst its on off road height...i take it its just a matter of spraying away and being patient watching? Honestly delighted right now Laughing
Post #407972 6th Oct 2016 4:05pm
miggit
Sweet!
I will say that in off road mode with the engine off you should be able to hear if there's anything amiss, I found that my front air bags were made Tetley Shocked Shocked I didn't need any fairy liquid... it sounded like a pit full of angry vipers Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #407976 6th Oct 2016 4:17pm
alistairh
Haha. Sounds pretty quite tbh...will try the squeezy bottle tomorrow..all being good then its on to the next Job Thumbs Up
Post #407987 6th Oct 2016 5:36pm
Page 3 of 3 <123
