Home > General > oh dear - wiper blades
T24RES
mzplcg wrote:
Not sure if these are the aero ones. Anyone tried them ?
http://www.wipex.co.uk/Landrover%20RR%2006%20c.htm
These will only fit the sport due to the hook fitting Big Cry Ian
Post #40780 4th Dec 2010 10:59am
T24RES
Rob2529 wrote:
Not sure if anyone would be interested?
http://www.jageng.com/garage9/product_info...68a5f2742c
I'd be interested, much prefer the flat blade wipers Thumbs Up Ian
Post #40781 4th Dec 2010 11:02am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
OK, popped down to pick-up the wipers, front and rear.
Even got them fitted FOC 'all part of the service' - noticed that the replacement rear is slightly longer than the old one - have the bill with LR part no's on so.
Foloowed by a "anything else i can check or do for you sir".
The auto factors one (bosch) were shorter [RRS] and a different fitting.
Post #40782 4th Dec 2010 11:09am
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I would be interested. Tried to fit flat blades by modifying the arms and blades but without proper facilities you can not get a good fixing.
Dan I am sure you mentioned the winter blades sometime in the past, did you ever try them?
Post #40785 4th Dec 2010 11:30am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I was asking about the Jager engineering ones and after mixed response and a lukewarm attitude from Jager I got a set- wouldn't bother to be honest. I'm still trying to find wipers that fit the blocks properly- the Bosch ones they mention are US only and Jager wanted £25 shipping. Also the blocks don't look "CNC" machined, more like they were bitten out of acrylic then sanded to shape with a brick.
I'm going to find wiper arms with a widely available fitting which are a decent construction and then weld them to the right length/angle onto the LR boss. Then should be able to just buy replacement VAG or similar.
By all means try Jager but caveat emptor.
Post #40788 4th Dec 2010 11:48am
Stephen.125
http://gallery.me.com/stephen.wood125/100003/IMG_0753
http://gallery.me.com/stephen.wood125/100003/IMG_0754
Some pictures, excuse the crappy quality it's lashing down here.
Another point- they skip quite a bit and take a while to tweak. And look very home made from inside the car.
Post #40789 4th Dec 2010 11:56am
Ok so jags are a ball ache an not that good. Could you take them off the car an take some good quality pics along with measurements? If you could i will try an get some adapters machined to suite a good blade avalible over here. If it works get a load done? Might take longer than buying them jag but hopefully be better.
Post #40798 4th Dec 2010 12:20pm
T24RES
Thumbs Up Thumbs Up Ian
Post #40803 4th Dec 2010 12:25pm
Stephen.125
Don't see why not- well volunteered. Thumbs Up
I'll strip them down today or tomorrow and get some pics uploaded.
Still thinking more about proper wiper arms as they FFRR one are made from the same quality stuff they use for kit kat wrappers.
You sound like you know what you're doing so I'll get you decent pictures and you can go from there
Cheers Thumbs Up
Post #40809 4th Dec 2010 12:41pm
My dad has a disco2 and they use the same stupid wipers as us. He's Censored off. He's got the engineering contacts. His main point of contact will be his mate who owns camel laids shipyard, he's a landy nut and races them so will want a set for himself. A wiper arm would be the best option as we wouldn't need adapter etc it's just finding one that will fit. I will leave that one to you.
Post #40830 4th Dec 2010 3:45pm
