Home > Technical (L322) > Deleting the PCV system on a BMW 4.4. IS it possible? |
I'm afraid not. You couldnt block the ports as the pressure build up would burst your seals all over the place!
3rd Dec 2010 5:44pm |
herman maire Member Since: 28 Nov 2010 Location: up north Posts: 51 |
Thanks for the reply Dan,
3rd Dec 2010 9:48pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, as dan has said, i think there has been many posts on the pcv system, the pipes were not up to the job from the factory and thats why so many have been replaced,i think they have addressed the issue and now are made with a better rubber that will not deterioate and fail.. i am sure it would of been done if it was possible, if kept serviced and inspected it should be fine, V8 facelift Range Rover Autobiography 22" wheels.
3rd Dec 2010 11:04pm |
Ok, ok... I will install all the new parts and hopefully not have to mess with the pipes for a good while.
3rd Dec 2010 11:12pm |
to tell you the truth i only cleaned my one out, i dont think tere is any other parts in side,
4th Dec 2010 9:42am |
