![]() | Home > Maintenance & Mods (L322) > Which Optima battery can I install? |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1560 ![]() ![]() |
A 110aH won't fit into the hole on the RHS. I found with the P38A, that a 100Ah deep cycle combine with the starting battery (through a dual battery system) wasn't enough capacity when running the fridge in summer. The car interior could easily be over 40 deg C. I use solar panels to keep the battery charged when camped. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Ah ha..... we now have a eureka moment |
bruzer Member Since: 16 Nov 2015 Location: Seattle, WA Posts: 44 ![]() ![]() |
It's actually a 2010 supercharged. And the cargo socket is unplugged every time I get out the car as a precaution. This morning the car didn't start up after sitting for two nights straight. Battery voltage was at 9.8V. Took my car into the dealership this morning for it's 75,000 mile service, mentioned the battery issue and they said you're not gonna get more than about 20 minutes on battery before the system shuts down - claims this is by design. They're going to test the battery, test for unexpected power draws, etc. (says car shouldn't be drawing more than 0.35 A when off).
Dealership tested the battery and it failed. That solves that mystery.
Good Luck Buddy |
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 ![]() |
I use an O'Rileys Auto Platinum I think size 49 and 110 ah. It is an AGM. Sears AGM seems cheaper. I think almost all of the AGM batteries (sold in the US) are made by the same company in the USA. I would go AGM personally.
The battery is rated at 730 A, but when they tested it it could only put out 306 A. The battery was installed 3 years and 2 months ago, which means it was a replacement and the battery it replaced (most likely the original battery) also mustered about 3 years. Is this the normal lifespan of lead acid batteries with these vehicles?
Nevermind about the battery in the trunk/boot question, just remembered a solution was already referenced earlier the the thread. Thanks everyone for your help on the original and subsequent questions. Here's what I've learned from this whole experience: - Optima yellow top batteries are a bit more involved to custom fit/install in L322 because of height - Optima yellow top batteries current top capacity is only 75 Ah compared to 100 or 110 Ah of OEM/factory batteries - Optima yellow top batteries have numerous reports of reliability issues since factory moved to Mexico years ago - L322, or at least MY2010, will only run 20 minutes on battery before shutting down (by design) no matter what the reserve capacity is rated at for the battery - most batteries are rebrands of about 3 actual battery makers - AGM batteries are unofficially advised against by dealerships for Range Rovers - a secondary battery in the trunk/boot may be the best option if installing extra electronics and concerned with power consumption and vehicle starting issues (battery must be the same type, AGM or lead acid, as the front battery) |
My ffrr has a Bosch battery in it and it's a 5 year warranty ![]() ![]() ![]() ![]() As for battery options for the boot / trunk, as long as it's 190mm (7 31/64")heigh, 175mm (6 57/64")wide and less than 354mm (13 15/16") long then it should fit. ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
I had to replace the batteries in my wife's mobility scooter last week.
