Home > Maintenance & Mods (L322) > Gearbox drain
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Gearbox drain
Changed the gearbox oil on the 4.2s/c today. It was last done at 100k by the dealer and it seemed about time now that she has clocked 210k. I removed the filler plug only to be deluged in a litre of black oil. I then removed the drain plug and another 3 litres drained out. I managed to collect a further litre from the sump tray.
I was wondering why there was 1 litre above the filler plug level? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #407410 2nd Oct 2016 6:04pm
When you start the engine the litre above the filler plug circulates round the system, so it isn't excess fluid it's required. You need to make sure when you refill that you have the engine running and top up to the level of the filler plug, refit the plug before switching off or you'll lose another litre
Post #407413 2nd Oct 2016 6:14pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
RRBlue - That's a job I'm going to be doing soon, did you drive the car first to get the fluid warm before draining it? 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #407431 2nd Oct 2016 7:14pm
RRBlue
Yes just to get the oil warm 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #407432 2nd Oct 2016 7:23pm
RRBlue
Thank you 47p2. That is helpful. When I change it again at 300k, I will just crack open the filler but leave it in until oil has drained from sump plug! When I refilled, I did as you say and filled with engine running, cycling the gears within the temperature range specified in the manual. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #407457 2nd Oct 2016 8:54pm
