ok so the blue to blue is video in motion that needs to be activated
http://www.cat.kwebdesign.co.uk/product_li...uct_id=376
Features
Video in Motion Harness enabling TV picture to be viewed whilst on the move (passenger use only).
Plug and play
Listen to CD while watching TV,
Change TV channels from steering wheel controls
Switch "Video in Motion" ON or OFF from the auto reverse button.
Compatible with: MK2, MK3 AND MK4 systems on X5 /3-E46/5-E39/7- E38.
Compatible with Range Rover up to 2005.
NOT TOUCH SCREEN MODELS
Black to Black
http://www.cat.kwebdesign.co.uk/product_li...uct_id=385
Features
Auxiliary interface for BMW/Range Rover/Rover 75 Just plugs inline at your TV tuner allowing you to plug in a Dvd or playstation etc, this also allows you to repeat whats on the front screen to rear screens if fitted.
Fitting is very quick and easy full fitting instructions included plugs into your tuner box, just unplug the white plug and fit the lead in line and connect you Dvd etc.
Also if a mommentary switch is fitted along with this it would allow passengers to change TV channels from the back.
This is only compatible with the VDO TV tuner in these model vehicles: Bmw E46 3 Series,E39 5 Series, X5, Range Rover & Rover 75.
If you wish to add a reversing camera as well see item AV2BMW.
