Home > In Car Electronics (L322) > Modifications found in my boot
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
can anyone help with the cables photoed below ?
one cable is black connector to black connector audio + video in with audio + video out (guessing this is for reverse camera?)
the other cable is blue to blue a red,white and brown wire run outside the plastic sleeve go into a little circuit board then back in to the blue connect there is no external connections on the blue lead just the added circuit which I can't see 100%
Post #407414 2nd Oct 2016 6:14pm
espaceboy
video in motion cable perhaps
Post #407436 2nd Oct 2016 7:31pm
Lukie
I did think that, however I did try with the analouge tv tuner turned on when I drove off, warning message poped up
Post #407438 2nd Oct 2016 7:49pm
Lukie
ok so the blue to blue is video in motion that needs to be activated
http://www.cat.kwebdesign.co.uk/product_li...uct_id=376
Features
Video in Motion Harness enabling TV picture to be viewed whilst on the move (passenger use only).
Plug and play
Listen to CD while watching TV,
Change TV channels from steering wheel controls
Switch "Video in Motion" ON or OFF from the auto reverse button.
Compatible with: MK2, MK3 AND MK4 systems on X5 /3-E46/5-E39/7- E38.
Compatible with Range Rover up to 2005.
NOT TOUCH SCREEN MODELS
Black to Black
http://www.cat.kwebdesign.co.uk/product_li...uct_id=385
Features
Auxiliary interface for BMW/Range Rover/Rover 75 Just plugs inline at your TV tuner allowing you to plug in a Dvd or playstation etc, this also allows you to repeat whats on the front screen to rear screens if fitted.
Fitting is very quick and easy full fitting instructions included plugs into your tuner box, just unplug the white plug and fit the lead in line and connect you Dvd etc.
Also if a mommentary switch is fitted along with this it would allow passengers to change TV channels from the back.
This is only compatible with the VDO TV tuner in these model vehicles: Bmw E46 3 Series,E39 5 Series, X5, Range Rover & Rover 75.
If you wish to add a reversing camera as well see item AV2BMW.
Post #407441 2nd Oct 2016 7:57pm
