Home > Off Topic > Assistance with outside lights
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Oh learned friends
I wonder if someone can help me out. I have two lights either side of my gates but I bought the wrong ones as they both have an independent air (so they come on/off not in sync)
Now I'm sure i've seen them before but I'd ideally like a sensor light that has a live or switch feed so that I can power the second when the first turns on.
Can anyone tell me what type of light i need to get..?
Ot shall I just go for a separate PIR sensor and wire it in line from the power.?
Thanks Ash
2016 SDV8 AB
Post #407418 2nd Oct 2016 6:19pm
It depends how they are wired as to whether you can get to the switched live of the PIR - some lights let you tap into it, others don't...Where you wire the supply into, if there are 4 connections then you're in luck - otherwise separate PIR is the way to go.
I have some with a 4 way terminal block - Live, Earth, Neutral & switched live - so I could run additional lights by using the switched live (and earth & neutral) from the first one Thumbs Up
Post #407455 2nd Oct 2016 8:50pm
comports
Thx Alistair
I'll have to remove one to take a look - I ran all the cabling and wired them up when I did the gate posts and gates but I can't remember if they were 3 or 4 core Rolling Eyes
Worse case, I'll pull them out and use a single 4 core with feed to the three core (without)
Do you have a name for the lights as none of them seem to have the extra switch live listed.? Ash
2016 SDV8 AB
Post #407456 2nd Oct 2016 8:54pm
Sorry - can't remember, but when I opened the back there was 4 way terminal block.
You should only need 3 core cable - the other side go the PIR you just use the switched rather than permanent live.
Post #407462 2nd Oct 2016 9:01pm
Not mine - this was a google search - but looks something like this
Post #407463 2nd Oct 2016 9:04pm
