Home > Technical (L322) > Headlight Igniter/ballast code
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Hi. Ive got the intermittent non starting off side headlight fault (its not the bulb) and having read the procedure for sorting it I am raring to get started. I have a 2003 td6 Vogue and can anyone tell me the part code(s) for the igniter/ballast unit?
Cheers. QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #407415 2nd Oct 2016 7:14pm
you can get the part number off microcat [link in wiki] or i'd be tempted to buy a whole unit off ebay and use that or its parts.. ... - .- -.
Post #407425 2nd Oct 2016 7:56pm
Spelunker
Thanks for this - can anyone tell me if it is the ballast or igniter that is more likely to be the problem. I only have it when turning the light on - once it is on it stays on (until you turn it off of course)..... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #407446 2nd Oct 2016 9:22pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
sounds like the igniter to me(the black box with the two wires going to the bulb inside the headlamp unit)
Post #407581 3rd Oct 2016 7:47pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
mines a bit like that.you put the lights on it works for a while then you get "CHECK DIP BEAM LIGHT" turn the lights off and on again its okay for a while and goes out again. it does this a few times and sometimes it ts okay. could this be the ballast or the igniter, or something else? gone fishin'
Post #407995 6th Oct 2016 7:40pm
ironhorse
the igniter starts the light (black box inside the headlamp unit) Thumbs Up
the ballast keeps the light on(silver box screwed to outside of headlamp unit) Thumbs Up
so your problem is the ballast
dont use cheep bulbs they scrap the ballast Big Cry
Post #408003 6th Oct 2016 8:54pm
Spelunker
Surely if it wont come on every time it is the igniter? QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #408027 6th Oct 2016 10:25pm
ironhorse
Yes yours is the igniter
Andyboy,s problem is the ballast
2 different faults =2diffrent fixes
Post #408066 7th Oct 2016 9:21am
andyboy
Thanks Ironhorse Thumbs Up gone fishin'
Post #408677 10th Oct 2016 7:47pm
